XTR shifter doesn&#...
[Closed] XTR shifter doesn't shift nice, Why?
Hi
I have an xtr 10 speed shifter which unless a new inner is fitted doesn't shift as light and precise as it should.
I run 1 by 10 with a one up 42t with rad cage.
This shifting has always been like it, I bought the shifter new.
Any one else had the same problem?
Thanks
Posted : 05/12/2014 7:27 pm
Mech hanger bent ever so slightly ?
Posted : 05/12/2014 7:32 pm
clutch mech's tend to make them feel a bit heavier?
Posted : 05/12/2014 7:36 pm
No that's fine, it's also fine once a new inner is fitted but wears very quickly. I use SS inners.
 cnud
I have this, in my case it's caused by the way the cable loops from the rear chain stay into the mech cable guide at a steep angle. Too much friction, but unfortunately nothing I can do about it, believe me I've tried.
Posted : 05/12/2014 7:39 pm
cnud - how about a full length outer and don't faster it to the last guide on the chainstay; leave it to loop round more gently ?
Ugly, mind ๐Ÿ˜ณ
Posted : 05/12/2014 7:43 pm
 cnud
Yep got the full length outer. Bit of a heel rubber to, so I reckon not using the last guide would end in tears ๐Ÿ˜€
Posted : 05/12/2014 7:46 pm
could go along top tube and down the seatstay โ“
you [i][b]know[/b][/i] you want to
Posted : 05/12/2014 7:53 pm
 cnud
Hmm
Posted : 05/12/2014 8:49 pm
I use a V brake noodle at the junction with the rear mech. It seems to help.
Posted : 05/12/2014 9:39 pm
Have you tried changing the outer cable. I've found with better cables the inners last longer, but when it gets to a stage the inner needs changing the outer also needs changing as it's damaged/worn/contaminated/slick coating has gone.
Posted : 05/12/2014 9:50 pm
I have same setup as you and had the same problem. The issue was friction in the cable from bb along chainstay to mech. I changed inner and outer and it's back to finger light shifting again, even with clutch mech engaged.
Posted : 06/12/2014 12:04 am
I will take a look, and change it around.
Posted : 06/12/2014 12:14 am
