XTR M980 2x10 26/38...
[Closed] XTR M980 2x10 26/38 - can I fit a bash ring with it?
Hi all,
Looking to change my M970 XTR chainset to an M980 but rather than buy a triple and have to spend money on new rings too, I'd rather get a double to start with.
Looking at the pictures, it looks like there are some removable caps in place of the outer chainring which I assume I could just remove - is that correct?
Chris
Posted : 12/06/2012 11:05 am
correct
Posted : 12/06/2012 11:09 am
The removable caps are actually nuts on the 38T option.
With the triple, the outer chainring is threaded and acts as the 4 nuts.
If you fit a bash, you will cetainly need nuts and maybe a complete new set of nuts and bolts.
Shimano Tech Docs show it all.
PaulD
Posted : 12/06/2012 11:31 am
