Anyone know if this is possible? I've been offered a cheap m9000 double crankset which I'd want as a single ring setup .
Can it be done or are the double and single m9000 crank arms different?
Ta
Posted : 10/07/2016 11:43 am
Posted : 10/07/2016 11:50 am
Same crank arms, so you can run Shimano DCE rings or aftermarket ones as above.
Posted : 10/07/2016 12:48 pm
I've done this on 3 bikes. It works fine.
Posted : 10/07/2016 12:50 pm
Had one of these for about a year:
http://int.oneupcomponents.com/collections/all-products/products/xtr-nw-rings
Mounted on a 2x crank. All good...and colour-matched to XTR too.
Posted : 10/07/2016 1:41 pm
Anyone know what the difference in chain line is between the crank designed as a 1x and the double set up as 1x?
Posted : 10/07/2016 4:54 pm
It's the same crank. The chainring corrects the chainline.
Posted : 10/07/2016 5:25 pm
