XTR 11 speed cranks...
[Closed] XTR 11 speed cranks and gearing
7 Users
Probs going XTR 2x11 on my new xc build
It's a 29er and a bit unsure which cranks to order
General xc in Epping is my regular but with annual trips to the Lakes and Spain I need the gearing for the big hills when needed
Options are:
36.26t
34.24t
38.28t
I'm thinking 38/28 but is this right for a 29er?
MM
Posted : 12/11/2014 3:04 pm
What bottom gear do you normally use on what wheel sized bike?
Posted : 12/11/2014 3:08 pm
Difference between 26" and 29" is pretty much balanced out by 2t off the front for an equivalent gear inch.
So thatd be like a 40/30t on a 26" wheel.
Posted : 12/11/2014 3:10 pm
Coming from a 26" triple ring set up
Rarely use the granny. Only used in Spain, odd bit of Lakes.
Posted : 12/11/2014 3:12 pm
 adsh
Everyone's legs are different but IMHO big hills need chain rings with a bit of leeway for fatigue. 28 on a 29er is 30 on a 26er which is only two less than most middle rings - that's not big hill gearing for my legs.
With a 36 on the back then if you're fit 26 is OK if you are a strong climber. If you're doing 100miles and 5,000m I'd want 24. The 34 that comes with isn't too bad - a lot race with 1x10 and 32t?
Posted : 12/11/2014 3:15 pm
You can work it out if you know what the lowest gear was that you used on the 26" wheeled bike.
Posted : 12/11/2014 3:16 pm
If you used to use the 22/34 bottom gear on a 3x9, with 26" wheels, you'd need 24/34 from that list. Anything else will be harder work on the climbs (all other variables being equal).
Posted : 12/11/2014 3:21 pm
More like 10% rather than a flat two teeth - makes a bigger difference the bigger the chainring.
At the end of the day, it's a personal choice. I'd have 28/38 of those.
Posted : 12/11/2014 3:23 pm
Depends how fit you are and how you like to climb. Personaly I don't mind standing up and mashing like it's a SS so I'm quite happy with a 34t single and 11-36 on my 29er (its rigid too, so gets away with high gears, if it were FS I'd need low gears to sit and spin). I only use the 36t on short to mid length climbs, longer climbs I use the middle gears and stand up and mash/rest like it's a SS.
If I was going 2x I'd want a low gear, otherwise it's pointless, probably the 26t version, I find 24t too low, I can't spin quickly enough to maintin any momentum over obstacles.
Posted : 12/11/2014 3:27 pm
Don't forget the cassette on 2x11 XTR is 40-11 too...
Posted : 12/11/2014 9:42 pm
