XT composite middle...
[Closed] XT composite middle ring - compatible with other chainsets?
Hopefully getting a raceface chainset tomorrow and have a spare 32t XT composite ring, will this fit the crank arms or is it specific to shimano?
Posted : 10/12/2011 10:08 pm
 loum
you'll know before us, but it could go either way.
I've got a 32 tooth SLX composite chainring that doesn't fit on my SLX crank-arms because the tabs inside the bolt holes are too thick. I've also got a 32 tooth XT chainring that does fit ๐Ÿ™‚
Sometimes it makes no sense
Posted : 10/12/2011 10:57 pm
I am afraid I don't think they will fit. My SLX mid didn't fit a Race Face Evolve and neither did a Saint 36t.
Posted : 10/12/2011 11:07 pm
May not fit without some tweaking but pretty much anything can be made to fit if you own a file (or better, some sort of power grindy thing)
Posted : 10/12/2011 11:23 pm
If the BCD (Bolt Circle Diameter....there are quite a few different ones about) is the same it may fit with a bit of filing. If it ain't then forget it.
Posted : 10/12/2011 11:33 pm
Recent raceface and shimano all have sensible BCDs luckily. Though, can't speak for 10-speed stuff but 9-speed was pretty much standardised, thank gawd.
Posted : 10/12/2011 11:42 pm
Even with the same BCD (104), the 'arms' of a Shimano composite chainring are longer. So, if you want to put a composite chainring on cranks not designed for it, you need to either file off the small tab on the cranks (quite easy), or the chainring 'arms' themselves (more difficult). Don't know about Raceface, but it took me about fifteen minutes to adapt a set of deore cranks to fit an SLX composite chainring - mask off the bits you don't want to damage with the file, file off the tabs, touch up with a bit of black paint - done! Worth doing IMO - much smoother & quieter shifting with the composite middle.
Posted : 11/12/2011 12:50 pm
it fits fine
Posted : 11/12/2011 3:17 pm
