XML Light
[Closed] XML Light
4 Users
Just got one of these and very impressed with light.
But can anyone advise on handlebar mount. My light has a U (bar) shaped fitting attached and a couple of heavy dutry rubber O rings - Are these to clip on and then over the bar or am I missing a handlebar bracket- does not appear to be referenced in box or on instruction card.
Thanks
Richard
Posted : 27/09/2011 9:57 am
You sit the curved bit on your bar and then secure it with the O-ring looped round the bar and attached on the 2 hooks on the mount.
Posted : 27/09/2011 10:02 am
As above, stick a bit of tape to the bar first thought to prevent it sliding about.
Posted : 27/09/2011 10:05 am
Thanks all, I had thought as much so must be learning!
Posted : 27/09/2011 10:10 am
2nd the tape - either insualtion tape or even better if you've got it is amalgamating tape as it really helps stop the mount moving.
Posted : 27/09/2011 10:11 am
