WTB tyre on Stan�...
[Closed] WTB tyre on Stan's Flow 29er rim. Anyone else had problems ?
I put a WTB Prowler on the Flow rim on the back of my 29er last night.
Everything went OK, until about 2:30 hours in to a trailquest today (did I mention I ride trailquests ?) when one side popped completely off the rim without warning.
I put a tube in and everything seemed OK when I blew it up, so I carried on.
Is it just an incompatibility issue ?
Do some tyres work better than others on Flow rims ?
Posted : 28/12/2010 11:18 pm
Prowler on a rear flow tubless worked fine for me.
Mine was a meat eating pimpdaddy white flow though.
I've got loads of different WTB's on different flows without any problems.
Posted : 28/12/2010 11:26 pm
Hmmm, OK.
I run mine at 45psi, if that makes a difference.
One thing I noticed as I blew it was that there seemed to be a few ripples in the side wall. They disappeared once it had some pressure in it, so I assumed they were caused by riding it the short distance between it going bang and me actually stopping.
Posted : 28/12/2010 11:34 pm
45psi is a high pressure for a Stan's rim, I generally wouldn't inflate to more than 40psi on mine to seat the tyre and mostly I run about 30psi or so - somewhere in my brain is lodged a vague recollection that maximum recommended pressure is only about 40psi or so depending on tyre size - edit: I think that's just their 29er rims. Anyway, 45psi does seem a lot.
Posted : 28/12/2010 11:40 pm
The sticker on my 29er Flows says 40psi max for 2.0" tyres and 38psi max for 2.3" tyres.
Not a problem for me as i run mine with tubes.
Too high a pressure?
Posted : 28/12/2010 11:47 pm
Thanks for the replies.
I got the rim second hand, there are no stickers on it.
I just had a look at http://www.notubes.com/product_info.php/products_id/345 and you're right, 40psi max with a 2.0 tyre.
I ran two different Kenda tyres at 45psi, before swapping to the WTB, without problem. I only swapped them because both Kenda tyres developed mysterious bulges in the sidewall. Maybe I was just lucky with the pressure.
Posted : 29/12/2010 8:34 am
i ran a prowler on flow rim for a few months. no problem with it blowing off but it did leak through the sidewalls. as above, probably the pressure.
Posted : 29/12/2010 11:07 am
