Quick question - currently have an SLX rear mech that pulls from the top and have (on impulse) bought one used that looks like it is probably designed for side-pull. Can I use it do you think?
And yes, I do mean Rear mech, not front.
Thanks.
WTF!? All rear mechs pull the same. Unless you mean low-normal (cable pulls mech down to small sprockets) or top-normal (more common, cable pulls mech to bigger sprockets).
Either way, as long as you have a Shimano shifter it'll definitely work, the function may just be reversed.
There is no such thing as side-pull or top-pull on rear mechs.
shadow mechs have the cable entering nearer the top if that's what you mean.
If you want to use a standard mech you may need a longer gear cable and a bit of new outer to make a smooth run into the mech.
I think that's probably what I mean.. Thanks
