Would you buy a (ne...
[Closed] Would you buy a (new) fatbike for ~£1k?
Sorry to bump an old post.
Am I right in thinking that one of the Wazoo riders on here had a set of On-One carbon forks on their Wazoo. I seem to recall there was an issue fitting them with regards to the brakes but I'm maybe wrong.
The Pasak Forks I bought have died, so looking at a new front end setup. Been recommended the On-One set by a fellow fatty fiend.
Posted : 23/04/2018 6:03 pm
The OO fork may have an issue when mounting a caliper and getting it sitting in the right place on a disc. It's a front disc spacing / rear disc spacing conflict between hub and fork. I can't remember which way round it is.
The cure is to machine or file row caliper adapter / mount by 4 mm. It's easy to do.
Note, it's not filing 4mm off the fork mounts btw.
Posted : 23/04/2018 6:24 pm
The On One carbon forks are Rear Disc Spaced, Dahedd, the default Wazoo front wheel hub is Front Disc Spaced (the more modern standard). It won't work.
You either need to...
Source a new front wheel that has an RDS hub
Source an RDS front hub and then rebuild the original wheel rim using it
Delve into the dark art (voodoo? :D) of lathing the brake adaptor and then using a file so that your FDS wheel rotor spins freely inside the caliper, something kayak23 did and bri-72 on here did at least.
I've yet to complete my attempt at the kayak23/bri-72 "hack," after bri-72 sold me his spare lathed adaptor last autumn. I've also got an RDS hub I won on ebay, which I've yet to get around to trying to rebuild a wheel with. Sometimes I miss not being able to a fat front wheel, but fortunately, I got one of the last FatNotFat 29er wheelsets from PX which had an RDS front hub, which I've been using for tyres in the 28-60mm range.
Just a thought, but as far as I can see, PX don't seem to stock the carbon fat fork any more.
Posted : 23/04/2018 6:44 pm
No they dont appear to sell them on the PX website anymore but there is someone selling 6 new sets on eBay.
Posted : 23/04/2018 7:05 pm
I've not gone through the thread to see if it's already there but just in case anyone else is looking to change the bearings in the original bottom bracket on the Dune,  details are as follows.
Bearing code is - 173110-2RS
I found them at Kinetic for £5.50 each.
https://www.kineticbikebearings.com/173110-2rs.html
[url= https://farm1.staticflickr.com/825/28387011378_1f2c52df3b_z.jp g" target="_blank">https://farm1.staticflickr.com/825/28387011378_1f2c52df3b_z.jp g"/> [/img][/url][url= https://flic.kr/p/KfsRuE ]Untitled[/url] by [url= https://www.flickr.com/photos/79912681@N06/ ]kayak23[/url], on Flickr
Good news for me as I was teetering on buying new cranks, the lot. Nothing wrong with these Lasco cranks. They actually seem fairly light. The bb is heavy though obvs.
Posted : 21/05/2018 8:23 pm
Nice one- I got as far as discovering it had replacable bearings but then I damaged a taper so I just replaced it all, good to know it can be kept alive.
Posted : 21/05/2018 8:46 pm
How did you get them out of the bottom bracket shell...?
Posted : 21/05/2018 11:46 pm
The Dune.
New bb bearings, new front wheel bearings, new headset and new fatter rubber.
Can't get over the size difference in the new tyres. Looking forward to trying them out. Went up beautifully ghetto tubeless.
Looking steezy. 😎
[url= https://farm1.staticflickr.com/946/40499459560_a78446ca2e_z.jp g" target="_blank">https://farm1.staticflickr.com/946/40499459560_a78446ca2e_z.jp g"/> [/img][/url][url= https://flic.kr/p/24GNjm9 ]New fatter rubber on the Dune. May 2018[/url] by [url= https://www.flickr.com/photos/79912681@N06/ ]kayak23[/url], on Flickr
4" Juggernaut on the right, 4.8" JumboJim on the left.
[url= https://farm1.staticflickr.com/877/27437093787_91d483d7ab_k.jp g" target="_blank">https://farm1.staticflickr.com/877/27437093787_91d483d7ab_k.jp g"/> [/img][/url][url= https://flic.kr/p/HNwh6a ]Untitled[/url] by [url= https://www.flickr.com/photos/79912681@N06/ ]kayak23[/url], on Flickr
How did you get them out of the bottom bracket shell…?
I used a workmate, putting the bb between the jaws and tapping the spindle to knock each cup off, then the same with each bearing. Wasn't particularly graceful but it happened.
Posted : 23/05/2018 8:48 pm
 mm93
Looks great pal, I've got to get round to doing similar to mine before long as I'm getting some play in the BB now ,and im still on the original 2x8 .I may  just get a race Face crank set though,still undecided about going 1x 10. What gearing are you running?
How do the tyres feel compared to the jugs? Ive never had a problem with grip with the jugs particularly but the self steer on the front does my head in when pressure is below about 9.5 psi.
Posted : 24/05/2018 9:49 am
@kayak23 I hope you are running that combo with a slammed stem and some TT bars to get full aero advantage. 😉
Posted : 24/05/2018 10:09 am
@mm93 - self steer, I find it worst on roads as the tyres have so much grip! The first ride I'd got the pressure too low, particularly on the front, I kept feeling like I was going to high side like a motorbike. I got some more air in ASAP.
I don't have a Dune, I've a Singular Puffin, but I fitted a RaceFace AEffect crank with direct mount chainrings. I actually run an oval 28T (it's the only practical way to get such a small oval ring) with 11-42T Sunrace cassette. The range is fine for what I do on the bike - I've only felt that I've needed a lower gear once and I'm rarely in the 11T - If I want to go fast on easy terrain the fat bike isn't really the bike for it.
I don't know what the chainline is like on the Dune but 4.8" JJ might be a problem with a 2x drivetrain.
Posted : 24/05/2018 10:13 am
 mm93
Good advice Whitestone thanks.
Posted : 24/05/2018 10:24 am
MM93
Looks great pal, I’ve got to get round to doing similar to mine before long as I’m getting some play in the BB now ,and im still on the original 2×8 .I may  just get a race Face crank set though,still undecided about going 1x 10. What gearing are you running?
I'm running a 30T front and a Sunrace 11-46 rear 11 speed. It's bang on really. If that can't get me up any climbs I probably need to have a quiet word with myself.
It does spin out a bit though when I'm chasing roadies who have the audacity to overtake me on road sections 😉
I've literally only got the tyres on last night and just had time for a spin up the street so can't comment on that. I also was totally fine with the Juggernaughts. I think you have to adjust how you ride things is all. I learned this pretty quick after wanging it into slidey surface mud a few times and ending up on my face. Fatbikes have float.
I'm expecting the JJ's to roll slower but I think they'll suit my riding better as they have a much more robust sidewall and general construction than the Jugs.
I don’t know what the chainline is like on the Dune but 4.8″ JJ might be a problem with a 2x drivetrain.
I reckon I'd agree with that. There is about 5mm to spare if that from the chain to the tyre on the 46 tooth ring. I imagine you'd get contact on a granny.
Posted : 24/05/2018 10:37 am
 mm93
👍 ah thanks,I may copy you LOL.
So I can put  an 11 speed cassette on the original wheel okay and would need 11speed specific shifter,mech,chain and chainring? All food for thought thanks.
Posted : 24/05/2018 10:57 am
4.8 JJ's will fit with the original 2x8 gearing on a Dune, just - but will rub the tyre occasionally.They roll far better than the jugs that came with it, maybe as the tubes aren't in there.
Posted : 24/05/2018 5:21 pm
Juggernauts are actually bloomin slow, presumably from carcass resistance/hysteresis rather than tread.
Posted : 24/05/2018 5:28 pm
I agree, but when they're blown up around 20psi they're pretty quick... Used one on the back at last years Dyfi with about 15 psi in it & a floater on the front, worked pretty well TBH. With the Dyfi's rep for ruining tyres I didn't fancy destroying the JJ's I'd just bought !
Posted : 24/05/2018 5:40 pm
Hi, I just read this entire thread.  It basically took me my whole holiday Sat by the pool.
During that time, I bought a stock Dune on eBay.  I haven't  taken delivery yet.  My question is this, would I be able to ride the London to Brighton off road on it with my friends on hardtail mtbs, or will I struggle?  I'm not Bradley Wiggins.
Posted : 01/06/2018 12:04 am
Yeah, you will. Just run slightly higher pressure tyres than perhaps you might normally.
They roll along ok really.
Posted : 01/06/2018 12:43 am
i've finally got me a dune. loving it, but definately going to need some blutos and a dropper post, due to terrain, and my knackered shoulders and neck : )
so self-steer question: i'm running the original juggers, will stick with them til they're gubbed due to budget, 2nd biek etc etc. but finding the self steer, or not-steer more like, pretty bad, and am convinved i can feel it from the back as well.
i do have them pretty soft. 0.4 bar = about 6psi in Freedom units. i'm assuming a bit harder will help? but i'm pretty light - 65kg and this seems to be a sweet spot for dealing with loose stoney stuff and not dinging the rims.
also, from a quick skim, seems liek other tyres might suffer less from self steer?
basically the jugs are a bit shit and i should stick some JJs on? that's what i'm expecting to hear : )
i'm only riding dry trails, so mud -type grip not an issue, but i would like a bit more traction. even at 0.4 bar the back wheel spins out surprisingly often. jumbos again then?
i reckon when i get some blutos on this will sort all of this a bit. will be able to run both front harder, and the back probably needs to be a bit harder anyways
Posted : 27/06/2018 9:59 pm
Starting point for tyre pressure seems to be about 1psi for each 10kg of body weight so I'd say 6.5psi for the front and a little higher for the back. With fat bike tyres 0.5psi can make a big difference so get an accurate low pressure gauge.
Then just go out and ride and figure out what works for you. If you change tyres then repeat the process as the tyres are so big, deep sidewalls, etc. It's worth going for the higher TPI tyres as well - my wife has the 27TPI Surly Nates and they are way heavier than my 120 TPI 45Nrth Van Helgas.
Posted : 27/06/2018 10:12 pm
Through a process of trail and error, I've found 7.5 psi at the front and 8.5 psi at the back to work for me (I'm somewhere between 70 - 74 KG). It's a bit slow on the road, but has enough compliance on the bridleways and byways I normally cycle on. I think I could go a bit lower, but the drag on the road would be too much.
Depending on how you've set-up your tyres (tubeless or not), then defo get a low pressure gauge. The difference in psi between my early morning rides and afternoon rides with the kids can be as much at 1.5 psi, depending on the weather.
- For presta
- For schrader
Posted : 28/06/2018 10:24 am
and as far as self steer is concerned? you get noticeably less at 7.5 than at 6.5 say?
or is it more about the tyres and their carcass?
and yes, weather makes quite a different. left it in the (hot) sun the other day and the tires gained easily a few psi
Posted : 29/06/2018 7:40 am
I find that self-steer is almost an all or nothing effect so I'll get self-steer at 7.5psi but not at 8psi. That's just with that particular tyre. If I change tyres then the tipping point might be between 8.5psi and 9psi. As stated above, it's a process of trial and error but you don't want to be putting huge pressures in just to be safe as you'll be pinging off everything.
Posted : 29/06/2018 8:20 am
I’ve mentioned this before but the higher the TPI the worse the self steer I’ve experienced.
I can’t see how having a flimsy side wall can benefit accurate steering.
Posted : 29/06/2018 8:45 am
yep, makes sense zippy,
and yes whitestone, i'd rather a little self-steer than getting pinged about.
found 2 part used jumbo jims for 30 € the pair this morning so i reckon i'll give that a go.
just need to find some cheap blutos now!
Posted : 29/06/2018 9:06 am
Hang fire with the Blutos,  don't get me wrong they're nice & do improve the ride somewhat, but the real game changer for me was fitting JJ's...…
Quick list of what I class to be the order of importance of things to change first, basically the difference it made to how the bike rode & to cost of changing it.
Brakes & Discs  - it was nice being able to stop
H/bars - the stock ones are like a piece of scaffold pipe, actually scaffold pipe would probably have more give in it..
Tyres - Floaters for deepest winter & JJ's for the other 8-9 mths, Tubeless,which is probably more noticeable on a fatty than on any other type of bike - you lose the hefty tubes & the tyres just work better !
Dropper seatpost - This could probably be higher in the list as I find the Dune to be very arse up in the air when riding & it's great to get the saddle out the way.
Drivetrain - swopped to a 1x10 set up 30x11-36, which works fine for me. Get loads of traction on the fatty so if it's proper steep I can usually stand up & stomp it up there, or walk 😉
& then finally, some forks with bounce.
I've stayed with the stock wheels as I've yet to find any cheap ones to replace them with..
TBH I'd have probably bought a more expensive fatty that didn't need so many bits changing to make it a better bike had I given it a bit more thought before buying it !
Posted : 29/06/2018 9:42 am
emac65 thanks for your thoughts, but i need spension. currently thinking 80mm
the stuff i ride around me is too much for my neck and shoulders otherwise and i get serious headaches.
also a few small jumps and drop-offs i like to do, but can't take rigid.
i've already swapped bars and stem, chainrings, and a dropper is on the list. i'll do brakes eventually and tubless is aalready done, mostly because of puntures.
Posted : 29/06/2018 12:17 pm
We did look at a Dune (well I did as I happened to be near a Go Outdoors) when my wife was looking for a fat bike. She ended up getting the only XS Surly Wednesday coming in to the country! Comparing her bike with mine (Singular Puffin) there's a definite "heft" to hers. There's 250g difference in the frame so everything else is in the wheels and tyres. (That's generally true of fat bikes - the Puffin frame is just 200g heavier than the Swift for example.)
As I stated earlier she has 27tpi Nates whilst I have 120tpi 45Nrth tyres. The biggest difference is in getting going - I'm up to speed much quicker than she is but once going there's not much in it and the extra momentum of her heavier tyres lets her push through things. I bought my fat bike second hand as a rolling chassis so had summer tyres but for me it's mainly a winter bike (I got it to do the Rovaniemi 150 race) and having suppler tyres is a big plus in snow. Needs a picture 🙂
Posted : 29/06/2018 12:38 pm
I am pretty sure I way well have asked this in the past but don't recall the answer and there are a fair few pages to get through!
So, the medium Dune, what sort of lower height range would this suit? I'm thinking for the Mrs who is 5'5".
Thanks
Posted : 29/06/2018 12:52 pm
Normal Man,  I'm a smidge under 5' 8" and have a medium. The seat post isn't long enough for me, and doesn't quite have enough set back, other than that it fits me pretty well. I was a bit too stretched out on the large. Make of that what you will...
Posted : 29/06/2018 6:10 pm
Thanks for the reply.
Posted : 29/06/2018 9:41 pm
 mm93
Can anyone point me to a set of reasonably priced cranks and bottom bracket for my dune please,I would  prefer to stay 2x10 I think. I was going to go for the race Face ride but they seem to be out of stock everywhere. There are some SRAM gx 1000 cranks on eBay and ive also seen some SRAM x5 but my mind is blown by all the different sizes and options ,what bottom bracket would I need for these? Thanks
Posted : 26/08/2018 1:08 pm
Discovered earlier that JJs have a rotation and the rear was wrong way around on my Wazoo, I've been defying physics for months and have somehow not died! 😮
Posted : 26/08/2018 6:57 pm
 mm93
I think your dune frame & fork will probably be lighter, this is based on my experience of the Kona from a couple of years ago. I'd say the dune has a slightly more trail friendly geometry & the Kona a more long distance bike packing vibe, much like an original fat bike.
Posted : 04/10/2018 10:21 am
Anyone got a set of Calibre Dune or other rigid 150mm forks they would like to sell?
I've had 90% of a bike sat in the shed for 3 years after running out of £££ and the price of Bluto's went from £280 to £500+ in the meantime!
Posted : 04/10/2018 2:53 pm
Just finished getting through this mega thread!
New Dune owner here, with the split inner tube method is the inner tube reusable? I used to just taping a rim and wacking some sealant in..
Posted : 22/04/2019 10:43 pm
If you are careful. If you can cope with the aesthetics of a baggy trim, it will be easier to re-use.
Posted : 24/04/2019 12:08 am
Absolutely reusable, just a case of lining it up. I used the AV10 tube- lighter than the heavier AV10D usually recommended, and cheaper too- and it's exactly the right size. I cut it right down a seam line, no trimming at all, and it sat perfectly into the rim with just enough to go up the sides. I did have to be a bit careful with fitting but fatbike tyres are so loose anyway that this is no trouble.
Posted : 24/04/2019 12:23 am
Cool, thanks guys.
So a strip of foam slightly narrower than the rim bed, two SV10 inner tubes and a bucket of sealant should see me on my way then?
Posted : 24/04/2019 8:03 am
Just a heads up for you fatty owners, there are a few fat bits in the latest PX sale...
https://www.planetx.co.uk/s?sort=price-asc&q=fat
It includes some fat rims made of cheese 😉 and some front wheels (1x q/r, 9x bolt-thru at time of writing post, doesn't say in typical PX style but I'd guess they are all Front Disc Spaced {so good for Dune/Wazoo default forks plus Bluto, not good for On One Carbon Fatty forks).
Posted : 14/05/2019 4:09 pm
The emmenthal rim is literally the same rim as comes on the Dune standard btw.
Posted : 14/05/2019 4:28 pm
Thinking of painting my fatty. Show me your non white OOF.
Posted : 24/06/2019 10:31 pm
Page 48 / 49
