After a lot of thought, nearly spending £1500 on a bike without even riding one, coming back to reality and settling for a Dune, i've bought a second hand thing for a very reasonable amount. (Low)
Going shortly to collect it and just hope it's as straight and good as I'm led to believe.
Pics shortly 🙂
What gives O-o?? Mamoths ordered Sunday, arrived tuesday while i was at dialysis - by Yodel too! (I figured they couldn't kill rubber!) Way to go 😀
Here's my new toy.
Medium fatty with carbon forks, 1x10 with new chain and cassette and as originally sold components.
Got it for under £400 with the original 2x Sram components and a spare rear tyre thrown in. Very happy with the deal and a even had a good chat about biking when I picked it up.
[URL= http://i124.photobucket.com/albums/p31/twonks_photos/DSC_0483_zpsjimeemlw.jp g" target="_blank">
http://i124.photobucket.com/albums/p31/twonks_photos/DSC_0483_zpsjimeemlw.jp g"/> [/IMG][/URL]
Not sure whether to put it back to 2x10 with the big cassette for a silly low gear, or just go to a 28 or 30t front and keep it 1x10 ?
As I bought it with the intention of having a laugh climbing up things, I'm thinking of reverting to 2x but, would appreciate other thoughts.
If I go to a 28t front and leave it single ring - do these fit onto the smaller 64pcd (iirc) of the granny ring and how do people find them?
Already thinking of a dropper and going tubeless.
So after a year of being fat curious I now have to wait a whole 8 days till be fat fixation comes to pass and although not technically under £1k Id still like to join the party ,especially after spending the last 2 hours reading this page about tyres.
Long and short Lives in the Peak district ,always muddy and wet , Jumbo Jims not all that clever , used to a Mary up front, looks like im going to have to get a set of Minions or 45nrths
Hurry up Canyon !
I've stuck with 2x10 on my fatbike for now, as I like climbing cliffs, but I've got a 28T on my 1x10 Smuggler. It's mounted on the granny position of a double chainset (with a bash ring in the outer position, mainly for looks) and seems to work well. It moves the chainline in a bit, of course, but that suits me fine as I spend most of my time up that end of the cassette anyway.
Twonks, go for 2x10. This gives you access to the fatty's bestest party trick: the ability to climb just about anything. A fatty without is a fatty wasted, in my humble opinion. Then, at the oher end of the scale, you still have the option of a 36t ring pushing 11 for any steep track or road scariness.
If you have only 1x10, you'll have both fair gaps in the range, plus neither a truly low nor truly high gear available. That's lose-lose-lose in my book.
Thanks and you make a case that is difficult to argue against. Other than aesthetics and a slight weight reduction (which are not really valid), going back to 2x is the way to go.
Will sort it in the morning and go for a ride round the back end of Cannock. There is a particular hill I always struggle with and run out of grip on the regular bikes.
Should be interesting with loads of grip and super low gears 🙂
Which tubeless valves so I need for br2250 wheels? Sure I read somewhere that the normal Stan's ones don't work with these rims..
Dune owners, I've bought a second hand FSA Comet fat crank and BB. The non driveside cup bottoms out before it should, with a spacer added it feels ok. Any idea why?
Has anybody else had any issues?
The BB is a 100mm DH.
Maybe because of the mech mounting plate normally on the driveside, if you've gone 1x something?
Yep, its 1 x 10.
On closer inspection the threaded part of each cup is twice as long as a standard Hope BB. I think its just run out of thread inside the frame.
It works with a spacer on each cup but the instructions say to only fit a spacer to one side.
I've tightened it all up and while it turns ok there is definitely more resistance than normal. I might try it with a standard Hope non driveside cup and no spacer.
The reason I haven't used the Hope BB is that the fit of the crank is very tight on the Hope bearings and pulled the bearing out of the drive side cup on removal.
Mine is now 2x10 with a 24 and 36 at the front and 12 to 42 at the rear.
Works fine in the car park and now off for a proper ride to see how it feels.
The Sram X5 kit feels better than XT on my HT. Always been a die hard shimano fan but this may change my mind - will see how it fairs after a bit of sand, mud and rain 😉
Taped my rims up yesterday using gorilla clear repair tape.. Pumped like a madman only to then examine why my jumbo Jim's weren't going up.. There the non tubeless ones!
Anyone used the Maxiss mamouths? Are they as crap as they say in the wet? £30 from on one can't be sniffed at..
Success at last, Gpx cup on the drive side with one spacer, Hope on the non driveside. As I suspected, not enough threads for the longer GPX cup.
Goldigger, put some sealant in it!
Goldigger - like lightman says, you gotta lube those babies up - you weren't attempting a dry run were you?
Goldigger - MemberWhich tubeless valves so I need for br2250 wheels? Sure I read somewhere that the normal Stan's ones don't work with these rims..
It's a wee bit fiddly becase they're singlewall rims- I use the alu superstar ones but they need a little finagling to work right because the taper sticks right through the rim and stops the lockring threading down. Various ways you can tackle that, I put cup washers from avid brakes (or cantis, same thing) on mine, perfect. There might be a better way though.
Guilty as charged, I was trying a dry run. All my wheels have gone up dry, might just be lucky there.
I did put a rubber washer on the valve to try and seal it up better.
Might have to borrow the neighbors compressor
Even on TL tyres, without sealant you'll lose pressure in the event of a puncture
Thanks for pointing out the obvious...
I inflate my tyres get them seated on the rim, remove the valve stem and add sealant...
Just seemed weird that you complained of a tubeless tyre deflating is all. Just trying to help
Not complaining of a deflating tyre, they need to have air in to do that.
I've not even got to the adding sealant part.
I didn't get passed stage 3 below..couldnt get the tyre to hold any air.
1.Tape rim.
2.Mount tyre.
3.Pump up like mad to seat the bead.
4.Let the air out.
5.Remove valve stem.
6.Add sealant.
7.Put valve stem back in.
8.Pump up.
9.Shake rim to distribute sealant.
10.Check for leaks.
Is it stock Dune rims? HAev you got the tyre to go onto the bead? (ie step 3?). I found that basically impossible without foam padding, even with a big compressor, the rim is just a bad shape for tubeless.
I'd agree with NW. I have the On-One Emmental (I think the same rims as the Dune). No luck at all getting the tyre seated (using a 'Ghetto' Airshot made from a 2l pop bottle). Just isn't happening
By the way, Goldigger, I wouldn't put the valve stem back in (Step 7). You'll get air in the tyre faster without it. Can then remove pump (or air supply), finger over valve and quickly screw the core back in. Obviously you'll lose a few psi but the tyre should stay seated
Goldigger - MemberThere DT Swiss BR2250 wheels..
Which don't really have a good profile for tubeless in my opinion
No, they do not. Good beads but bad profile. There's more about this in the thread but there was supposed to be a tubeless kit for them, DT canned it, so they're like half a tubeless rim. Good news is once the tyre's on they're great. I found putting cable ties right round the tyre then gradually tightening them did the job (reusables, I'm not a savage) but I wouldn't fancy doing them with just a pump tbh.
I did try two leather belts linked together around the tyre, yanked them up nice and tight but still didn't get the tyre to go up...
i used an old 26" tube around the outside of the tyre on my 2250s after seating one side with a tube, went up fine with a flash charger
Look similar to the marge lites I've got. Nothing happens with just rim tape, even with a compressor. the tyre just sits there, not a glimmer of a suggestion of inflation.
You just need a strip of closed cell foam to fill the gap. weighs bugger all, just secure it with parcel tape or something, it's done its job as soon as the tyre's up, so it doesn't matter if it comes loose later.
I've had to admit defeat with tubeless on my Wazoo as well. Even with a fatty stripper over the rim it just won't take.
Not sure if its the wheel or the tyre (4" Floaters)causing the issue but it won't even go close to sealing. I think the tyres warped tbh (that or both wheels are buckled) even seems to fit oddly once back on with a tube. Was going to buy new wheels from On-One but none in stock just now (they have also officially withdrawn the fat not fat wheel set, no intention of sell in it again)
So out of curiosity what Would be the smallest size inner tubes I can pop into the wheel?
All my floaters have tubless(ed) fine
Goldigger - MemberI did try two leather belts linked together around the tyre, yanked them up nice and tight but still didn't get the tyre to go up...
I think the advantage of cableties is it tightens more evenly, you can cinch them up individually. But still, some tubeless feels like it's going to happen and it's just a matter of effort, other tubeless feels like it might or it might not and they're the latter I think. I was pretty close to adding foam (just for mounting, not for the bead) but I've always got it to work so far.
Have had mixed results with Schwalbe SV13Fs. They're light but they're 26 x 3" and even in a 4.0" tyre they don't inflate evenly - the rubber overstretches in places and it's only a matter of time before it splits. Would not put one in a 4.8" tyreSo out of curiosity what Would be the smallest size inner tubes I can pop into the wheel?
The SV13Js are quite a bit heavier but work fine. Fit/forget
This gave the impression that you were:
And this:
Always easier to inflate, or at least, seat the rims on the bead (your initial goal) with core removed. Some soapy water around edge of rim helps to pop the bead up, on troublesome tyres I somtimes add a little sealant to the tyre before adding air, helps to create a seal on the first desperate tyre dance/shake off.
http://www.planetx.co.uk/i/q/TYSCJJLS/schwalbe-jumbo-jim-liteskin-fat-bike-tyre from £53, going on photo they are 4.8", but in typical PX fashion there is a quality description of product. 😆
All JJs are 127 tpi I guess 100/120 refers to the width in mm (4.0"/4.8")
steveojo69 - Member
I've ordered one of the Planet X pannier racks, I'll fit it at the weekend and let people know how it performs.
Has the rack turned up yet? Did you buy panniers at the same time and if so, do they look they will die if you look at them in the wrong tone of voice? 😯
With regard to setting the BR2250 wheels up tubeless: maybe I'm just lucky, but I've just taken the Bud/Lou off and put the 4.8" JJs back on. So, that's three sets of tyres I've put on these rims now and they've all gone on just fine with an airshot, which was a pleasant surprise given the volume of a 4.8" tyre.
I set the rims up with a few wraps of Gorilla tape. So nothing special there. I did run the tape tight to each side of the rim (so it goes over the bead). Maybe that helps. I also use a tube to seat the bead on one side, before hitting it with the airshot to seat the other side.
As Northwind says, once they are on they are pretty secure. I've run as low as 3psi over rock hard frozen mud with no problems.
rocketman - Member
now also avaliable in 4.4
Has anybody tried these? I love my 4.8s but keep wondering about something a bit narrower for the summer (lighter and lower the BB). But by all accounts the 4.0 don't work as well as the 4.8, so I wonder about 4.4.
I bought a 4.4 during the Athleteshop JJ bargains ~6 weeks ago, but it is still in the box being shielded from UV, still masses of rubber to wear on my 4.0 set from last Easter.
Visually, the tread looks no deeper than on the 4.0s (~3/5/10mm centre to outer edge), whereas I'm led to believe the thread is much deeper on 4.8s.
Is that right? I didn't know that. I've never measured the height of the tread on my 4.8" JJs, but it's not very aggressive.
Mind you, my only other fatbike (front) tyre reference is a Bud !
n0b0dy0ftheg0at - Member
steveojo69 - Member
I've ordered one of the Planet X pannier racks, I'll fit it at the weekend and let people know how it performs.Has the rack turned up yet? Did you buy panniers at the same time and if so, do they look they will die if you look at them in the wrong tone of voice?
Rack is a little flimsy but should be ok for light duties. My Altura panniers don't fit very well so I am looking for a cheap pair that fit.
It doesn't sit horizontal either.
Jumbo Jim 4.4's came standard on my cube nutrail. I like them but haven't tried anything else. Only place they can be hard work is deep mud, otherwise they are great.
Thanks. The 4.8" JJs are crap in the mud too if that's any consolation. Hence the Bud/Lou combo in the winter. It's great to be back on the JJs though. Almost feels like cheating 🙂
