Would on one carbon...
[Closed] Would on one carbon fatty forks work for a 29+ front end?
 mos
Thinking of putting these on the front end of a lurcher to accomodate a 29+ front tyre. The length is the same as their monocoque 29er fork but the offset is 10mm more. Would this totally screw the steering or what?
Posted : 12/12/2014 9:08 pm
It'll change the handling a bit putting the point of contact with the ground further out front so it feels a bit 'boaty' but it won't be a massive change, obvious, but not huge. We have a 29er out back in the warehouse that has been tried with all sorts of forks on it, only a few were 'bad' choices.
Posted : 12/12/2014 9:43 pm
Also 29+ is more like 31 inch diameter
Posted : 13/12/2014 9:16 am
The fatty fork is designed for a 135mm frot hub - a 29+ plus tyre will run fine on many regular MTB forks - I have a 445mm Pace RC31 on my bike running Surly Knards. FYI tyres are 740mm diameter.
Posted : 13/12/2014 1:47 pm
 mos
Cheers guys. I've already got some WB Rock Solids which i think will be wide enough, so i"ll give them a whirl first. Might not be quite the right look for a Lurcher though.
Posted : 13/12/2014 5:10 pm
