would an old Roadbi...
[Closed] would an old Roadbike frame/forks be suitable for building a Cyclocross bike?
 taka
Hi,
looking for a winter alternative to my mountain bike would an old steel road frame and forks work as a cyclocross bike? the main problem would be brake clearance because it wouldn't have brake bosses?
tom
Posted : 19/11/2010 10:48 pm
Problems;
Tyre clearence
Brake mounts (fixable if steel and you can weld... Maybe drop-out mounted disc adaptor for the rear?)
Otherwise, things like geometry and the strength of it may be an issue but won't stop it working.
Posted : 19/11/2010 10:52 pm
 bol
Probably not. Apart from not being strong enough and maybe being too steep, most frames wouldn't have the clearance for the tyres.
Edit: beaten to it.
You could always make me an offer on the 56 cm tricross rolling chassis I've just made available!
Posted : 19/11/2010 10:54 pm
 taka
cheers for the offer Onzadog but i would have to chop my legs off at the knees to fit on it ๐Ÿ˜‰
Posted : 19/11/2010 10:59 pm
Depends how old, but yes it's totally doable.....if.
The frame took 271/4" wheels and ideally steel. The old frames have bags of width and depth for clearance.
Talk to Ceeway and they'll supply the braze on canti bosses an engineer would be able to do them.
Also if the frame has the old style long ends with no hanger, running it singlespeed is a piece of pee.
Just gonna grab a piccy. And a bloke on plus one lap did it to a Colnago.
 taka
so im better off looking for a proper cx frame & forks then
 taka
it would be single speed and yeh its a 27 1/4 wheels and steel most of the bike is steel
Posted : 19/11/2010 11:01 pm
 taka
i have also got my dads old emelle mtb frame which can take 700c wheels and canti's so that may be a better option
Posted : 19/11/2010 11:03 pm
This sort of thing, these old'uns were generally slacker anyway. I've ground off the pump pegs and lamp boss ready for powder coating. See the long ends.
Posted : 19/11/2010 11:04 pm
i think the cx frame has a higher BB too
Just brakes to sort then, worth a try.
DM Uni for rear http://www.a2zcomponents.com/02products_04adapter_05.html
Just front brake to sort now.
Posted : 19/11/2010 11:05 pm
If it was an MTB and you fitted 700cs the bosses would be in the wrong place. Mavic make adapters, but that would defeat the object.
Posted : 19/11/2010 11:07 pm
You could go fixed 8)
Posted : 19/11/2010 11:08 pm
 taka
oldgit its just like that only bigger
Posted : 19/11/2010 11:09 pm
 taka
bollocks ill just go brakeless its only to be ridden around the hills of hebden bridge
Posted : 19/11/2010 11:10 pm
fitting the braze ons is easy. Fit the wheels and mark them up for the engineer and hey presto you have one funky steel crosser for peanuts.
Posted : 19/11/2010 11:12 pm
 taka
i can do all the welding etc. got a steel workshop at my house ๐Ÿ™‚ and i think i have some of them braze on mounts in the workshop somewhere
Posted : 19/11/2010 11:17 pm
Flinky blip! I swapped it out for something smaller. Just how tall are you!!!!!! ๐Ÿ˜†
Posted : 19/11/2010 11:54 pm
 taka
Onzadog,
i read it wrong it might fit me im not used to cm stuff things work better in feet and inches ๐Ÿ˜‰ how much were you wanting?
tom
Posted : 20/11/2010 12:22 am
It's frame, forks, headset, seat post, mini v brakes and wheels including the stans converted tyres. Only just stripped it down and not thought about a price. It's in good condition. What sounds fair?
Posted : 20/11/2010 12:31 am
You could just use some deep drop calliper brakes.
eg something like these Alhongas: http://www.spacycles.co.uk/products.php?plid=m2b0s100p149
They say "Ideal for 700c wheels in a 27" frame", so should give plenty of tyre clearance.
Posted : 20/11/2010 2:01 pm
Erm onzadog, I too might be interested, email in profile
Posted : 20/11/2010 2:13 pm
