[Closed] Woburn
4 Users
 nim
Hi all,
Thinking of heading upto Woburn for an early (pre child duty) ride this weekend. Anyone know what the roads are like around there (I'm southern point of Herts and my road has been a no go since the snow came)?
Thanks,
Nim
Posted : 23/12/2009 11:22 am
 Jase
Not been up the woods but I live about 2 miles away and the main roads are all fine.
Where do you normally park?
Posted : 23/12/2009 11:26 am
 nim
Hi cheers for that. Only been once but parked on the grass verge up the road from the cross roads where the pub is i.e. as you go up that road, and there's an entrance on the right leading to the jumps.
Posted : 23/12/2009 11:32 am
 Jase
Ah yes, that road will be fine.
Wasn't sure what church road (leading up into woods from Woburn Sands) would be like.
Posted : 23/12/2009 11:39 am
 jedi
was all good monday when i was there
Posted : 23/12/2009 11:49 am
 nim
Cheers gents. Much appreciated. Is the better riding to be had on the jumps side or the other side of the road? Thanks
Posted : 23/12/2009 11:50 am
 Jase
What sort of riding do you do?
Posted : 23/12/2009 12:07 pm
 nim
Will be on a 5" FS which may be overkill but all I have at the mo. Like a bit of everything (techy singletrack, smallish drops etc) - trail riding/larking about I guess. Normal riding is Norh Downs (Leith & Holmbury Hill) but Woburn so much closer so makes sense to get to know it better.
Posted : 23/12/2009 12:15 pm
It depends on how long you are riding for.
Woburn has 3 section. Either side of Church road, which turns into a legal dirt road at the top. Even if I was only their for an hour I'd ride both sides of this road. Its a great time to go as the you will be able to see tyre tracks so easily. I found some new to me bits last weekend using this method
If I want a longer ride i cross the road here
http://www.streetmap.co.uk/map.srf?X=491272&Y=234365&A=Y&Z=120
ride down the track behind the church and turn up left through a gate
loads more single track in here
You can either leave this area the way you went in or you can follow your nose and you should get spat out here
http://www.streetmap.co.uk/map.srf?X=491629&Y=232665&A=Y&Z=120
Its the road and track back to where you started
Posted : 23/12/2009 12:45 pm
 nim
That's great, much appreciated.
Posted : 23/12/2009 1:14 pm
