Will this laptop ru...
Will this laptop run Zwift?
Microsoft Surface Intel Core i5-7200U (2.5 GHz), 8GB RAM, running Windows 10 Pro
Daughter has just upgraded from this for Uni, so idly thinking this might be my chance to finally jump on Zwift if it will run it OK...
Posted : 11/09/2022 7:40 pm
Specs wise, that should be fine, but in my experience the surface tablets never perform well due to overheating which then means the processor thermally throttles to slower speeds
I guess what I’m trying to say is you won’t lose anything by trying!
Posted : 11/09/2022 7:51 pm
@tomnavman. Interesting you say about overheating, I've noticed the bottom casing gets very warm! As you say, no harm in trying...this is the laptop, not the tablet mind
Posted : 11/09/2022 8:05 pm
If it works but gets warm, one of those cooling bases might help
Posted : 11/09/2022 8:39 pm
What gpu does it have? That will be the limiting factor.
Posted : 11/09/2022 8:47 pm
Should run fine, zwift runs on older intel iGPU's than that.
Posted : 11/09/2022 9:20 pm
I think the GPU is an Intel HD 620...
Posted : 11/09/2022 9:50 pm
It'll run it, just at the very lowest settings and probably less than 30fps.
Posted : 11/09/2022 10:28 pm
Off the top of my head, that sounds a very similar spec Surface to the 4 my better half has had for ~8 years and I get to use more sporadically these days for Zwift, used to be regularly used before the Zwift Android app got better and my mobile upgraded.
The Surface runs Zwift fine, however, in recent months it has developed an issue with overheating while simply surfing the web. Worked fine for the Zwift Insider Tiny Races quartet on Saturday afternoon, but was red hot after ~80mins use... Must remember to set up a fan blowing over it next time!
I use an Amazon Basics 3m USB lead and an ANT+ dongle with it, rather than native Bluetooth.
Posted : 12/09/2022 6:43 am
Try it. But I think it'll be fine. Basically I predict:
The game will run perfectly nearly all the time.
Graphics will be locked to the lowest level but that's normal across a huge range of devices, including some of the most popular.
And you will get framerate slowdowns and limited visibility up ahead in massive events, but it won't matter (again widespread and normal).
Posted : 12/09/2022 10:13 am
Be interesting to try running it through Geforce Now and Steam. Shouldn't have any performance issues then. Might give it a go tonight!
Posted : 12/09/2022 10:16 am
On a kinda related note, what's the cheapest way to get a dedicated PC to run Zwift at a decent. i.e. higher than the basic if not all super duper, graphics level?
I've been using wither the Android app on a 10" tablet or a Surface Pro for the past couple of winters, both of which run at bog-basic Zwift settings. Thig is I've now got an old 24" monitor that I can use to embiggen the experience and I'm wondering whether to just attach it to the Surface using a HDMI lead, or get a dedicated PC to allow me to have some better graphics.
Posted : 12/09/2022 11:00 am
@IHN it doesn't need to be that great. Old business spec desktops with an older better GPU are more than enough.
Posted : 12/09/2022 11:12 am
So what do I need to look out for spec/GPU-wise?
Posted : 12/09/2022 11:39 am
On a kinda related note, what’s the cheapest way to get a dedicated PC to run Zwift at a decent. i.e. higher than the basic if not all super duper, graphics level?
Are you on Facebook? If so, join the "ZPCMR - Zwift PC Masters & Riders" group.
There is a ton of info on there & people doing regular PC builds for sale. The page creator Dave Higgins regularly posts bargain PCs for sale on there.
I bought one from him earlier this year & it runs in ultra mode no problem at the 1440p setting. Apart from the wi-fi card not being suitable for my mesh set-up (so I replaced it) it has been rock-solid. It cost me £200.
Dave posted an ebay link yesterday to a PC for sale that will run Zwift in Ultra mode at 1440p mode for £143.
EDIT
Regarding the spec of mine.....it's
i3-4130 processor
GTX960 graphics card
8gb RAM
120GB SSD
600w PSU
Posted : 12/09/2022 12:12 pm
That's useful Stumpy, ta
Posted : 12/09/2022 12:24 pm
Stumpy beat me too it, was going to post the same FB group :D.
Posted : 12/09/2022 2:41 pm
Do you have a reasonably modern smartphone? As my S10e happily runs Zwift or RGT and then connects to a TV with a Samsung DeX connector. Hopefully will also connect with a simple USB-c to HDMI cable too, as I've got one coming on Wednesday and that will cut the cables down from 2 to 1.
Posted : 12/09/2022 11:10 pm
