Got a Cotic rocket (large) that I love but it makes my back ache on longer rides, I think because it's a little short. I currently have a 70mm stem on it.
Cotic recommend 80mm max. Would I notice the difference? What would it do to the handling? Could I go longer than 80?
Your collective wisdom is much appreciated in advance.
Lex
You definitely need to spend £150+ on a professional bike fitting to sort this out properly.
E mail davidtaylforth for more info.
Will I notice an extra 10mm on my length?
I was hoping this was going to be penis related 🙁
Layback seatpost?
'traffic-driving' knob gag ambiguity entirely intentional.
dropper post so no layback.
narrower bars...is that heresy?
10mm on your rocket?
Move saddle back/try layback
also check bar height
maybe the above and a longer stem as 5-10mm effective length on each could get you where it needs to be.
Maybe I should go into bike fitting... 😀
Depending on what part of your back is aching you could even argue going shorter would be beneficial.
or lowering you stem
or moving your seat
etc.
Someone with more knowledge than myself required. Try posting on bikeradar in the General section.
May be worth thinking about a few spacers under the stem, or a stem with a bit of an angle to it. Could be worth getting a cheap adjustable stem (they can be had for about a tenner I think) and just playing with that a bit and see how different settings feel. Or look at bars with less of a rise maybe?
Would that be General, General/General, Commuting/General, General/Commuting/General, General/Beginners/Generally/General/Road....
*repeat to fade*
What mrblobby said. Without pictures of you on it, it's very hard to tell, so playing around with stem height/ angle could be a best option.
But look at it from a different angle as well. You can get a foam roller off eBay for £9 and roll your back every morning. This will make you a bit bendier! My Osteo recommended this to me after a twisted pelvis and it really does make a major difference.
