Will a SRAM TLM cal...
[Closed] Will a SRAM TLM caliper work with a TL lever
Just wondering if an SRAM level TLlever will work on a TLM monoblock caliper, is there any difference with the internals of the TL lever which will make it not work with the TLM caliper?
I need a new lever so may be able to save some pennies if I get the TL version, but if not I'll get the TLM lever instead
Posted : 21/07/2018 12:45 am
I'm pretty sure the calipers are interchangeable. As far as I can tell, the only difference in the levers is the Bleeding Edge port; if you already have a bleeding kit for the TLM I think you will need a different fitting for TL.
Posted : 21/07/2018 7:08 am
