Just got some from my lbs and they aint going in cannot find any info on the web maybe you could do better than me
Rich
What size/code are they? Last Whyte I did bearings on used "imperial" bearings rather than "metric". EG; KP5A ( 7.94mm x 20.64mm x 7.14mm (Imperial 5/16x13/16x9/32))
Kinetic do Whyte bearings;
https://www.kineticbikebearings.com/catalogsearch/result/?cat=&q=whyte
Contact Whyte and ask them. Are they not covered by lifetime warranty as well? If so, surely hand in to Whyte shop and let them fix...I'd suggest the same even if they weren't covered.
I emailed Winstanleys and said
" Can I get a linkage bearing please"
Next day they posted me a full set.
Are they not covered by lifetime warranty as well? If so, surely hand in to Whyte shop and let them fix…I’d suggest the same even if they weren’t covered.
Bearings are covered if you are the original owner, labour is not, hence why some pay to "upgrade" from the oem bearings.
