Why is my bike crea...
[Closed] Why is my bike creaking so badly - it's embarrassing
Marin East Peak 2005 - high pitched creaking sounds coming from the frame all the time (well - not when it's sat in the shed). It's much worse over rough terrain. Any ideas what could be causing it? It's really hard to pinpoint where the noise is originating. It's not the BB. Could it be the quad link bits and bobs?
Ta loves.
Posted : 11/06/2010 11:35 am
when did you change the bearings last? any play in the frame/BB?
Posted : 11/06/2010 11:37 am
You say that, but I bet it does. It waits until you've closed the door and gone out, then it starts again. Mine does. I know because I've crept back and listened outside the door. Bastard thing.
Marin's of that age and older eat DU bearings. Whip the shock out and replace them.
Posted : 11/06/2010 11:39 am
DU = depleted uranium? ๐Ÿ˜ฏ
Blimey.
Posted : 11/06/2010 11:45 am
it's a Marin. It'll be creaky bearings.
They all do it. It'll be worse in dry weather too.
Posted : 11/06/2010 12:08 pm
derek_starship - Member
Blimey.
Ok just wear headphones then.
HTH
Posted : 11/06/2010 12:28 pm
So is this a chronic condition - like arthritis - that is worse in certain climatic conditions.
Do I have to ride round on a bike that sounds like a clown's car or will the problem be resolved by replacement bearings?
Are Marin the British Leylands of MTBs?
Posted : 11/06/2010 12:31 pm
Marins just creak, and the swing-arm amplifies the creaking.
Best bet, buy a new bike. Three to four grand should fix it nicely. Just think... Nice silence as you ride...
Do it! You know you want to.
Posted : 11/06/2010 12:35 pm
Perhaps it's the bicycle equivalent of a dirty protest...
Posted : 11/06/2010 12:50 pm
Most bikes creak at some point in dry weather.
Heres a non exhaustive list of possibles.
Cable ferrules - where they mount on cable guides and where the cables fit into the ferrules.
Cables and hoses - where they pass and touch the frame
Spokes if spoke tension is poor.
Quick release
rear mech spring or pivots
Mech hanger (if its removable)
Freehub body and hub bearings
hub axles
Suspension pivots and axles
Suspension bearings
Shock Pivots
Shock spring/pre-load collar (if coil)
Seatpost/seatpost clamp
Saddle
Bottom Bracket
Chainring bolts
Front mech pivots
pedal bearings/pedal axles
Cleat/pedal interface
Headset/frame interface
Headset bearings
Star-fangled nut
Fork Crown/steerer unit
Fork Dropouts/hub/QR interface
Stem/steerer/handlebars interface
Steerer spacers
brake and shifter mounts
Get the picture?
๐Ÿ˜‰
Oh, and your frame might be broken too.
Posted : 11/06/2010 1:03 pm
does it have the split h links? if so that's probably where the noise is from.
my mate has the split h link version, mine are one piece. his creaks like a bastard and mine is silent. new bearings and the whyte shock bushing upgrade probably helped too :O)
 jonb
Fit a hope hub, it'll drown out the noise.
Posted : 11/06/2010 1:18 pm
Friend had a mount vision with an awful creak.
It was down to the swingarm pivot bolts being a bit dry. Took them out 1 at a time, cleaned and greased then (bolt shafts too etc) and this cured the creak.
Posted : 11/06/2010 2:43 pm
