Why doesn't a ...
[Closed] Why doesn't a mountain front mech work with road shifters?
Or vice-versa?
Is it due to the chain line?
are the rings on road and mtb triple chainsets the same spacing between the rings, and same overall?
Posted : 18/11/2013 9:25 pm
its due to the cable pull ratio.
The pivot/parallelogram locations differ between road/mtb which means that every millimetre of cable pulled by the shifters does different things to the derailleurs.
Posted : 18/11/2013 9:38 pm
Xt 9 speed front mech is working with Sora shifters on my cross bike and a Deore triple chainset 22/32/44
Posted : 18/11/2013 9:41 pm
Using an X9 shifter, a 105 mech and a road compact chainset here with no problems (both 2speed/double).
Posted : 18/11/2013 9:46 pm
Using a XT front mech on a road triple, with 105 double shifter and using the"trim"position to get all three rings. Works unbelievably well!
Posted : 18/11/2013 10:43 pm
XT front triple with a campag veloce shifter on a drop bar tourer here.
Posted : 18/11/2013 10:45 pm
Have you routed the cable into it's clamp correctly? Some of the bottom swing mechs have a lug that the cable needs to go around the outside of, but looks like it should go on the inside of, which alters the pull ratio quite a lot.
Posted : 18/11/2013 11:59 pm
I haven't tried yet. Just figuring what parts I need to acquire ๐Ÿ™‚
Posted : 19/11/2013 12:51 am
Most do. The cable pull is slightly different, and the throw is less, but all bar the newest ones will work, you may just have to fiddle a bit.
Edit: actually road shifters/MTB mech works better than than the other way round.
Posted : 19/11/2013 9:23 am
 MSP
Old 9 speed mtb mechs will work with 9 & 10 speed road shifters as the pull ratio was the same, not sure about 11 speed.
Posted : 19/11/2013 9:29 am
Rear?
I was on about the front.
I have no desire to go 10 speed on a build (Salsa Vaya) so looking at XT 9sp rear and a 'touring' triple (48-36-26ish) up front. I have an unused XT front mech but need to get some shifters (was thinking Sora 9speed).
I guess I'll just see what happens ๐Ÿ™‚
Posted : 19/11/2013 1:58 pm
