Why do us lot accep...
[Closed] Why do us lot accept shoddy goods ?
WRONG, we have a bit of kit that simulates over ten years worth of riding, it sets the extremes of temperature sprays fresh and salt water etc, etc. Most companies that supply goods to the industry have this as well.
Does it also simulate loads whilst simulating the corrosion aspects you are talking about?
Posted : 18/09/2009 10:48 am
Wrong.
It is sold as a product an it's the product that has the warranty.
Your issue as a manufacturer vs supplier is completely different to your issue as manufacturer of the product v the consumer.
I'm not sure what you think I was suggesting here? I think you're getting confused with suppliers and distributors here, I'm talking from a design and manufacturers point of view, the distribution side of it and the consumer claim is irrelevant. The product is designed a set way, to last a set time. The warranty is the company acceptance of any stupid design mistakes or any manufacturing faults.
That mud-covered bike is perfectly acceptable and normal UK riding. Your warranty should cover such occasional use as it can be expected in a normal use of an MTB. If you're selling super-light race parts then you might well put a disclaimer on them pointing out they're not designed for conditions like those above, but it wouldnt sell well.
 juan
LOL at bling
Someone will be here in a minute telling you that MTB should be able to handle that...
do you have .... like a robot arm holding a rock that periodically whacks the tested component?
Posted : 18/09/2009 10:49 am
 juan
Yup so that does not include the muppet using it at the other side of the scale.
 juan
Water/keyboard interface...
LOL
Maybe I should ask fro a new one underwarranty
Posted : 18/09/2009 10:50 am
juan - Member
LOL
Just send your rock back to me and I'll replace it foc Juan
Posted : 18/09/2009 10:52 am
Yes it does. The whole point is that there IS a scale and it should operate anywhere within it, but if you take it off the scale it's not covered. It doesnt include someone crashing it, but it does include someone using it in muddy conditions. The point is that it should stand up to what can be expected of its normal use. If the public would normally use it occasionally in such muddy conditions then it should be designed as such, rather than designed as the manufacturer wants and then whinge when the user doesnt use it on clean dry trails.
juan - you do have some odd thought processes going on here.
When sitting down to design something the engineer should:
Assess what function it should perform.
Assess what what conditions it will be used in, including any reasonable extremes (UK market, plenty of mud).
Assess what limitations it may have (weight/speeds etc)
and then design for that part to last AT LEAST its warranty period in those conditions, or state when it is sold that it should not be used in those conditions. A good example would be watches - they're mostly designed to be splash proof because despite not being designed as divers watches most watches will at some point get a soaking or be taken swimming. The expensive watches that are not waterproof specifically state in their instructions/warranty that they are NOT WATERPROOF in any way.
Posted : 18/09/2009 10:53 am
 juan
Thanks druidh you are too kind 😉
Posted : 18/09/2009 10:59 am
LOL at bling
coffeeking already did 😉
Posted : 18/09/2009 11:00 am
There are some ****ing strange people on here who think that parts should not be designed to work within normal riding extremes. No wonder some parts fail early if there are engineers like you guys designing them. The old thinking on this was that if someone took your parts to the extremes you were glad to warranty it and learn how to improve the parts, not cry because someone used it a bit hard.
Posted : 18/09/2009 11:02 am
I'm perfectly happy with how all my bits and bobs have held up and performed in the last year (apart from my rear hub which needed new bearings after only 3 months).
Pikes have problem with losing travel and leaking through motion control, but after a year of abuse I don't mind too much, and a service is really needed anyway.
Posted : 18/09/2009 11:05 am
This thread should be sent back to the manufacturer. 🙂
Posted : 18/09/2009 11:06 am
 Del
you can leave that sentence right there 🙂
You are wrong again sorry.
The kit on that bike is not designed to take that amount of abuse and saying "normal British weather/riding conditions" makes no difference.
The stantions will be scrathed to f@ck and back, the rear mech only stayed on by a wing and a prayer, the chainrings will have worn down to ninja stars after an hour or so of grinding, the BB will be stuck solid and I would EXPECT all of that.
That's not a manufacturing/design fault it's a common sense FAIL.
Posted : 18/09/2009 11:07 am
[i]In most other countries, people don't ride when it's wet, they go mushroom hunting[/i]
This is a silly thread, but I have learnt one valuable thing that I shall take away from it. 🙂
Posted : 18/09/2009 11:09 am
[img] [/img] oo..eee, over here
I think a mountain bike should be designed to cope with that
Some of the components may well clog up with mud & either stop working or become hard to operate but after a wash down they should be serviceable again
Posted : 18/09/2009 11:11 am
The bike in the above pic is typical of people claiming they were JRA 😉
But this is the UK!!!111!!
They are.
Change the scratched stantions, new chainrings, strip and grease bearings etc.
Posted : 18/09/2009 11:13 am
juan - Member
LOL at bling
My Ti hardtail looked like that during SITS 2008. None of the bits have been replaced since and it's still working fine. A wee bit of wear on the fork lowers is all the damage. That's XTR, Marz Corsas.
Your opinion may be that I'm wrong. My opinion (as a design eng and someone who's worked on bike frame design and in the retail side of it in the past) is that I'm right. Those conditions are extremes that can be expected a few times a year in the UK. If you dont want to have your parts used in those sorts of conditions you should specify that in your warranty or not sell it to countries where this ever occurs. If you do wish to sell to those countries, or without any terms in your warranty you should design to suit possible conditions. Its basic engineering. Whether lawyers choose to play with rights and wrongs later is a different matter, but this is why you'll find most bike/motorbike/car tests appear to be rediculously harsh on the product, because thats how good engineers work.
As with druids, my bikes look like that most weekends during the winter, I have no problems with any of my parts. Increased maintenance (stripping bearings and forks) due to excessively muddy conditions are included in my warranty conditions and are sensible maintenance. If I used it like that all the time and never performed any maintenance I'd expect it to break.
Posted : 18/09/2009 11:15 am
"you'll find most bike/motorbike/car tests appear to be rediculously harsh on the product, because thats how good engineers work".[i]
Magura make both Motorbike and mountain bike products and I would take a guess that the kit they supply to the cycle industry is tested on the same machines that motorbike kit is tested on.
Posted : 18/09/2009 11:35 am
 Mark
...as do Fox.. who also make suspension systems for off road buggies as well as motorbikes.
Manitou too... 🙂
Posted : 18/09/2009 11:46 am
Indeed several MTB manufacturers are also motorbike ones and will share test facilities, though they may or may not share test strategies, they are usually very harsh. The ones that are less likely to subject their products to such tests are the ones that buy in cheap products from a catalogue of designs and just sell them on. These parts are often badly engineered or vastly over-engineered to compensate for this. Or of course they're copies of products that have been tested correctly.
In light of the fox fork problems I'd personally suggest they've under-designed or screwed up on their coating thicknesses and are not willing to accept it for a relatively small number of units sold - but that people should be aware that they need to maintain their forks, especially when used in extremes of environment. You dont buy an F1 car and expect to race it endlessly for a year without maintenance if the manufacturer says it needs maintaining every race. You simply dont buy the F1 car, you buy something more suited. Like a Marzocchi product, or at least the older ones that go on endlessly and still buttery smooth... 🙂
Posted : 18/09/2009 11:47 am
While things do break, they should last a specific amount of time. [b]The acceptable length of time is 1 year hence warranties being 1 year.[/b]
I got bored reading the thread so don't know if anyone else picked it up already, however, manufacturer's warranty does not affect statutory rights.
Stat' rights state it needs to be fit for purpose and last a reasonable period (paraphrasing). If you spent £1.5k on a frame and it broke a day, week or even six months outside the man' warranty period they (man')still have a legal obligation to sort you out (their options vary, check the regs).
That's perfectly reasonable, to think any product should only rightly last 1 year and/or is designed to do so is non-sensical verging on the daft 🙂
Posted : 18/09/2009 11:55 am
no - it's the retailers responsibility not the manufacturers
Posted : 18/09/2009 12:08 pm
 juan
They are.
Yep i concur. That is why the muppet on the other end of the product fail. Check the service intervals in MX. Guys change the fluids after each race. Actually I will always remember my first race. Finish the race and was riding in the paddock, every single bike from the bianchi team was being strip down to bare minimum and fully rebuild/regreased. I ask the mechanics if he was meant to do that, reply 'after each race yes'.
Posted : 18/09/2009 12:16 pm
 juan
Well you do but most of the people on here don't. If you strip and regrease your BB after a muddy ride it will indeed last longer than a month. If you don't it won't.
Posted : 18/09/2009 12:17 pm
Apologies for sloppy terminilogy, it is indeed the retailer 🙂
Posted : 18/09/2009 12:32 pm
If you go by the manufacturers instructions, you aren't supposed to do anything to HT2 bbs (at least for shimano ones).
Posted : 18/09/2009 12:35 pm
 RicB
Surely there's a difference between stuff wearing out through 'normal' and 'correct' use e.g. brake pads and tyres, and stuff wearing out because it's badly designed e.g. 40 quid BBs with insufficient sealing giving up within 3 months, SC Nomad/Blur frame bearings lasting 4 weeks etc (pre grease ports).
This problem is more painful than it was because stuff has gone up so much in price. A Shimano BB, cassette and chain is now >100 quid.
Besides Shimano BBs can't be user serviced ime.
Do the guys who use their 4x4s off road rebuild the whole thing on Monday evenings?
Posted : 18/09/2009 12:52 pm
I don't get it, if you know a part is shite and/or prone to failing why buy it and then complain when it breaks or fails in a relativley short period of time?
All it it with RF BB's is shite bearings and sealing, why the hell not - if you're hell bent on owning one change the bearings for SKF ones and smear a bit of waterproof silicone around the outside of the seal where it meets the BB shell?
Of buy one with decent sealing in the first place?
It's not exaclty hte most expensive part in the world to replace is it, a perfectly good, well sealed BB with stainless bearings can be had for £30, if said BB lasts 6 months at say 8 rides per month, at 2 hours per ride thats a total of 96 hours riding, nearly a whole 32p per ride, bloody expensive hobby this.
How many sets of brake pads would you go through in this time @ £15 a pair?
Posted : 18/09/2009 1:06 pm
My point was kinda that it should last a minimum of the statutory. There has to be some limit on the length of time the company is responsible for it though, being reasonable.
Posted : 18/09/2009 1:14 pm
 juan
Hang on a minute you mean people actually ride them off road... Now that is just weird.
Posted : 18/09/2009 1:34 pm
Del although it was bought off here it was still sealed in it's wrapper.
steve b 77 first r/f b/b i've used (and the last )gone with Hope now .where do you get b/b with stainless bearings for £30 ?
Posted : 18/09/2009 1:43 pm
oh and another thing when i used XT Octalink with bearings inside the shell used to get at least a year out of them.
Posted : 18/09/2009 1:46 pm
To paraphrase Keith Bontrager (i think it was he)
"cheap, light, durable, pick two".
Posted : 18/09/2009 1:59 pm
Many do strip and rebuild their 4x4s pretty regularly, yes. Certainly not as infrequently as the manufacturers specify, but as and when required by the terrain. I know one particular group who drive in clay-mud areas who need to strip and clean their brake system every time as it gets clagged up. IF you dont have the correct diff breather extenders on you need to drain and re-fill your diffs every time you submerge or you'll kill them. I have to wash and de-sand my kites every time I get them back from the beach or they'll end up smelling and wearing faster than they should.
The thing is it has to pass the "person of the street" test of long is resnoble when it comes to lasting.
With regards to the bike pic posted, mine has looked like that a fair few times over winter and i have only this year had to change the wheel bearings (they were 2 and a half years old)the bb is over a year old and most other bits have just been changed as they have natuarly worn.
I think that the components should be able to servive that aslong as you clean the bike after wards you ahould not need to re grease the bearings as they are sealed.
Posted : 18/09/2009 2:11 pm
Funny as Halfords are happy to warranty parts if it breaks within a year as long as the bike has been serviced.
Should be fit for for purpose but not abused.
I only ride dry trails as I can't be bothered to get wet or muddy I guess thats why my XT rings are still around.
My road bike needs a new chain and cassette after all the wet riding though. I'm not sure I would complain about that.
We do want customer service and things to last in this country if under normal use. But if my frame broke under normal use or riding to work then I sure am going to complain.
Juan-has a point if it is thrashed etc well it's broken rather than normal use. I odn't think oldgit has thrashed his stuff though-he's just miffed that it's made of cheese for such an expensive item.
You'd be lucky without proof of purchase to get any warranty.
Tyres-wear and tear.
What else comes under that cat?
Posted : 18/09/2009 2:14 pm
96 hours riding... How many sets of brake pads would you go through in this time @ £15 a pair?
Currently about 3 sets of pads a year at £6 a pair (superstar).
Posted : 18/09/2009 2:31 pm
Sorry to enter at such a late stage, but are people suggesting that component warranties should be void because their [i]mountain[/i] bike got muddy?
Posted : 18/09/2009 2:41 pm
Not at all.
We're suggesting you should take responsibility for your own actions.
You ride it into the ground it'll break.
Obvious.
Read the thread again.
Posted : 18/09/2009 2:47 pm
If you tried to warranty any part on this bike and showed the manufacturer the picture of how you rode it he'd be perfectly entitled to tell you to go p1ss up a lamp-post.
How exactly is he riding his bike?
Posted : 18/09/2009 2:57 pm
Page 2 / 3
