hi, just pushing the button on some deore brakes.
fork is a RS tora 302 solo air and frame is a cotic soul?
which adapters do I need? all this post to IS is a little confusing.
thanks
anyone? thanks
Threaded holes PM
Plain holes IS
It will probably be PM front IS rear.
I bought deore brakes from Merlin.
It depends on your rotor size.
For front Suspension fork and a rotor of 160mm you can direct mount the caliper, no adaptor needed. For 180 rotors or higher you need a post to post mount adaptor 5.99 quid from CRC.
For the rear I used post to IS on my cotic solaris, again rotor size specific.
Does this help at all?
Matt
The frame is definitely IS mount and I have a strong suspicion that a Tora 302 is IS mount as well. On the fork, IS mounts are 2 plain holes that go sideways across the fork, post mount are 2 threaded holes where the bolts fit from the rear.
googled tora 302, davewalsh is correct, they are IS mount by the looks of it.
