Which Loctite?
[Closed] Which Loctite?
4 Users
Main bearings on my Turner DHR are wobbling about a bit within the frame- have emailed Turner but suspect Loctite of some form may be the soloution.
Posted : 21/10/2010 1:29 pm
Locktite is only any use for stopping threads loosening. It won't cure ****ed bearings unless your talking about the bearings securing mechanism working loose.
Posted : 21/10/2010 1:44 pm
actually theswede - there is a bearing fit locktite designed for this very purpose. it will take up a few thou of play in a bearing housing. I have used it a few times
http://www.bearingshopuk.co.uk/loctite-641-bearing-fit-10ml-3142-p.asp
http://uk.farnell.com/loctite/135522/loctite-641-bearing-fit-50ml-btl/dp/1370136
Posted : 21/10/2010 1:48 pm
Just read thread properly. Thought he was on about grumbly bearings. I'll get my coat 😳
Posted : 21/10/2010 1:49 pm
Bare in mind you mind need to use heat to remove the bearings after you have used bearing fit, next time you come to change bearings.
Bazzer
Posted : 21/10/2010 1:55 pm
