Which ISCG 05 chain...
[Closed] Which ISCG 05 chain devices are compatible with a triple chainset?
Looking at fitting a chain device to my BFe that has ISCG 05 mounts.
I have heard that there can be compatability issues between the plate and "granny tabs" when using a triple chainset (with only a middle ring).
I dont want to have to grind off the granny tabs on my chainset, as might want to use it as a double sometimes, so looking for recommendations of devices that will work with the tabs still there.
Posted : 09/03/2011 10:33 am
I'm on old ISCG on my SX trail using a Blackspire stinger with an original Set of Saint cranks as a double set up with no clearance issues , only the bolt spacing is different for ISCG 05 stuff isn't it?
Posted : 09/03/2011 10:38 am
Thanks, but I am going single ring so will have no mech.
So what I want to fit is a chain device with both an upper chain retension device and also a lower roller.
e.g. E Thirteen LS 1 HT.
Posted : 09/03/2011 12:17 pm
