Which headset?
[Closed] Which headset?
3 Users
Guys, looking at a cane Creek Angleset to slacken my bike off slightly, but I'm unsure which one I need!
Its a canyon nerve am 6.0, currently with an acros Aix 03, tapered headset ( I believe!). So I looked at the website and it asked for several measurements and I put in what I thought - 1.5 inch lower, 1 1/8 upper and it said I needed this:
SHIS:ZS44 - 1-1/8" ZeroStack (ZS) upper
SHIS:IS52/30 - 1.5" Integrated (IS) to 1-1/8" Conversion lower
Anyone know if this is right? I was thinking going with the 0.5 degree change to drop the headset angle down to 68 degrees.
Ps does any other company do a similar product?
Posted : 09/12/2011 9:50 pm
Dont waste your money offset shock bushings are what you need!! Ill find a link for you.. hang on
Posted : 09/12/2011 10:07 pm
http://www.offsetbushings.com/ £10 bargin!!
Posted : 09/12/2011 10:08 pm
spudly1979 - Member
Check out Works Components before you do anything else, they make a cheaper, better product. I don't know whether they have one to your spec but they'll be able to tell you for sure. Weird really, they've been making their product for longer, in the UK, but most of the mags only want to talk about the shiny expensive newcomer.
Other options are available, K9 comes to mind and there's others whose name I forget.
Offset bushings are another good method, but not compatible with all frames- they shorten the "maximum compressed" length of the shock so that can cause frame parts to collide. Worth checking first. They also have other unpredictable effects, since with some suspension designs they'll mess with the linkage rates.
Posted : 09/12/2011 10:09 pm
Great! Ummm, what are offset shock bushings?
Posted : 09/12/2011 10:11 pm
Hmmm, had a look at the offset bushings and I'm a bit concerned as to what effect they'd have on the rest of the frame - bits colliding etc.
Posted : 09/12/2011 10:17 pm
This explains it quite well http://www.southerndownhill.com/reviews/components/offset-shock-bushings.html
In effect it lets your rear wheel sit lower and rakes your fork out, imagine fitting a slightly shorter rear shock
Posted : 09/12/2011 10:18 pm
spudly1979 - Member
Remove the spring,or air, from the shock then compress it all the way (if it's an air one, let more air out as you compress it). That'll show you the clearances you have and you can make at worst an educated guess from there.
Posted : 10/12/2011 12:00 am
