Which Grease for th...
[Closed] Which Grease for the CK BB Injection tool or bottom brackets in general?
What grease are people using for the CK Bottom Bracket injection tool or bottom brackets in general?
I was looking at some of that Phil waterproof grease, any feedback?
Posted : 30/11/2009 12:34 pm
I use Rock n Roll's super sticky white stuff, can't remember the real name of it right now though sorry.
Posted : 30/11/2009 12:45 pm
Silkolene RG2 here.
Tell me, do you know if the CK bottom braket injection tool work with any BB or just CK ones?
Posted : 30/11/2009 12:56 pm
Just the CK ones as there is no real seal at the rear of the bearing, this is where the grease enters the housing purging the used stuff out of the front.
Posted : 30/11/2009 1:25 pm
was looking at M760 BB last night and the only 'seeming' shielding it had was the external metal washer between the bearing out the outer plastic top hat.. so it might work? (with the top hat and washer removed)
Anyone tried it? (or care to try it?)
Posted : 30/11/2009 1:37 pm
Still don't think it would work as the King one has a small plastic shim that diverts the new grease into the bearing. If you take a look in a King one you'll see its different to a normal BB.
Posted : 30/11/2009 1:44 pm
I use a light semi-fluid industrial grease in this ๐Ÿ˜†
Posted : 30/11/2009 2:48 pm
