Where to got a non ...
[Closed] Where to got a non return valve for shock pump
Morning all.
Who does those little isolater valves (or what ever there called)for you shock pump.
That is all.. ๐Ÿ˜€
Posted : 18/05/2013 10:36 am
Didn't know you could get the valves separately but if it's any use I bought one of these a couple of weeks ago and it seems spot on for the money;
http://www.amazon.co.uk/dp/B003664C2W/ref=pe_217191_31005151_3p_dp_1
Posted : 18/05/2013 12:24 pm
I think Topeak sell one but it's snake oil, your shock pump should do it already, if it doesn't it's either a) broken or b) not really a shock pump. And the part is more expensive than a decent pump anyway so makes no sense.
Posted : 18/05/2013 2:43 pm
Brand new fox pump NW.My pikes are burning my brain trying to get the -ve right.They where easy until i had them serviced and upgraded by Si at loco.I,ll give him a tinkle..
Posted : 18/05/2013 2:50 pm
Hmmmm. You're not doing the "ah some air came out when I undid the valve therefore the spring must have lost pressure" thing are you? Don't ask me why I know about that, I certainly wouldn't make that mistake, oh no.
Don't know that pump to be fair so can't help there.
Posted : 18/05/2013 2:56 pm
Hahaha.Not that old chestnut NW.It's just all gone pear shaped.Have to pump the neg to like 50-60 psi more to get them to pull 2mm into the travel so i know there balanced or near enough when i take off the pump.It,s loosing the 50=60 psi out of the chamber just undoing it.If i don,t unscrew it super fast it just empties the -ve.
I know the pumps fine as i,m using it on other forks/shocks.
Sticky valve.?
Feels like it's just not shutting quick enough.
Posted : 18/05/2013 4:01 pm
