Where to get pressu...
[Closed] Where to get pressure gauge for low pressures
Got a Surly Endomorph tyre, tubes are Presta valves.
I'd like to get a pressure gauge that reads low pressures accurately, ie probably range 0 -30 psi.
Any ideas?
Even better if it is attached to a track pump ๐Ÿ™‚
Posted : 01/11/2010 5:12 pm
I've got one of these:
http://www.chainreactioncycles.com/Models.aspx?PartnerID=79&ModelID=8504
Possibly a bit over the top, as it gives you pressure to the nearest 0.1 PSI. It is light enough to chuck in your pocket if you feel the urge, and has a light and back-lit display option.
Posted : 01/11/2010 6:06 pm
I use a Topeak SmartGauge, it does Presta and Schraeder and reads to 0.1 PSI, can't see why you would need more accuracy.
Posted : 01/11/2010 6:35 pm
Dibbs - Member
You've got to make allowances for us old folk who think a gauge is round and has a needle ๐Ÿ™‚
My eyes can't make out the tiny increments on a gauge that goes up to 200+ psi.
A digital gauge solves the visibility problem nicely (assuming it is accurate at low pressures)
Posted : 01/11/2010 8:07 pm
You could also try a motorbike dealer, they'll have pressure gauges - you'd need a screw on adaptor though for the valves.
Don't get a digital one, they run out of batteries just when you need them most.
(And people on this thread are confusing precision and accuracy, going down to 0.1psi guarantees one but not the other...)
Posted : 01/11/2010 8:41 pm
I want it precisely accurate ๐Ÿ™‚
Posted : 01/11/2010 11:53 pm
 PTR
You want something like this,
http://www.itiuk.com/
The gauges are standard threads, take you 200psi gauge out of the trackpump, and put another one in.
Posted : 02/11/2010 8:33 am
surely the one on CRC is about as accurate as you could get? cant see why you would need anymore than 0.1 psi more accurate than that?!?!?!
Posted : 02/11/2010 9:36 am
i'm a professional measurement geek.
those 0.1psi gauges won't be calibrated. it's only a bit better than guessing what your tyre pressure is.
Didzy; your homework is to learn the difference between precision and accuracy.
(i also want a track pump with a low pressure gauge)
Posted : 02/11/2010 10:49 am
I'm sure I tried my Oxford gauge against the dial one I have for the trials bike (6psi front, 4 psi rear and a small psi difference can be felt in the riding at times) and it was "accurate". How exact does it have to be for a bike tyre? 4 to 5 psi is a big difference, 20 to 21 negligible in terms of what you can detect performance wise.
Tyre depots should have a calibrated master gauge which you could check against when next buying a car tyre.
The finer the gradations below 1 unit in my opinion then the less likely the reading is to be accurate - as someone hinted at above.
Posted : 02/11/2010 1:35 pm
