Where to find servi...
Where to find service parts for Fox suspension
I've generally run Rockshox up until now and I've always found things like a bag of crush washers and foam rings easy to come by.  For example:
https://www.bike-discount.de/en/rockshox-foam-rings-pike-35mm-x-6mm-20-pieces
https://www.bike-discount.de/en/rockshox-crush-washer-8mm-50-pieces
Now I'm running a set of Fox 34 forks and I'm struggling to find anything other than the full seal service kits which seem ridiculously expensive just to do a single lowers service.
Anywhere I can buy a big bag of crush washers and foam rings for Fox forks?
Failing that, anyone know if the Rockshox 35mm foam rings should work on Fox forks?  Crush washers I guess I should be able to find somewhere since I think they are 13mm.
Posted : 21/06/2023 10:57 am
Unless they are in warranty a foam ring is a foam ring ... (ID/OD/thickness)
Not sure how a 35 will fit in a 34 but I expect its fine ... In my experience if you try washing and reusing they grow more than that.
From memory my 32's have 2 different sized crush washers...
Posted : 21/06/2023 11:03 am
I would've thought so, a foam ring's a foam ring, isn't it?
Posted : 21/06/2023 11:11 am
When you find a source for crush washers, can you post it here please? Ta.
Posted : 21/06/2023 11:16 am
https://www.silverfish-uk.com/
Set up an account, doesn't have to be trade. I saved a set of fox forks from certain death (rebound knob rounded!) by spending a bit of time looking around here. Good on answering email questions too.
Posted : 21/06/2023 11:18 am
I'm half thinking about just 3d printing them.  The dimensions of the 13mm one are 15.7 x 12.9 x 2 mm according to a random forum post I found on the internet.  Use ABS and not PLA was the other tip.
Posted : 21/06/2023 11:24 am
https://singletrackworld.com/forum/topic/fox-34-foam-rings-whence/
According to @sl2000 the 35mm rings don't really work.  I shall join him in ranting about the lack of spares.
RWC do seem to sell the foam rings individually so that's an option, I guess.
I'll be sticking to RS from now on, I reckon.  Fox don't seem to want you to service your fork.
Posted : 21/06/2023 11:59 am
Fox don’t seem to want you to service your fork.
But they recommend it is serviced every 30 hours...
Posted : 21/06/2023 12:06 pm
Tried the bits4bikes seller on ebay? It's where I get my fork service stuff from. Good seller and helpful 🙂
Checked his listing and only has full seal kit - I'd message him and ask if he can supply the bits you need
Posted : 21/06/2023 12:16 pm
I get my Fox service stuff from eBay though I'll often reuse a crush washer and it's never done any harm.
Posted : 21/06/2023 12:34 pm
kelvin reacted
I'm going to reuse, and order some crush washers for next time. Cheers. 🤞🏻
Posted : 21/06/2023 1:29 pm
TF Tuned able to assist?
Posted : 21/06/2023 1:32 pm
They could only sell me full kits including wiper seals etc when I asked last time. It's ridiculous considering Fox say crush washers and foam rings should be renewed at much shorter intervals (even if you reuse foams and washers a few times, a wiper seal will still far outlast them)
Posted : 21/06/2023 1:53 pm
kelvin reacted
 LAT
i’ve seen foam rings on aliexpress. i’ve not searched for crush washers, but they are probably on there.
Posted : 21/06/2023 2:20 pm
1.25 off silverfish site for a crush washer.
Posted : 22/06/2023 4:23 am
kelvin reacted
