Where can i get fra...
[Closed] Where can i get frames anodised?
Might be a stupid question, but does anyone know where i can send frames to be anodised or is it not that simple?
Posted : 16/02/2010 6:00 pm
Its not that simple, I tried it, I had a customers Frame needed re anodising under warranty, so got the frame back took it to be stripped and polished pre ano, they dipped the frame in the tank, then the problems begain, because the frame had been out in the weather it had got contamination that the eye could not see, and this made the anodising very poor, the other thing that happens is any steel or brass fitting desolve in the ano tanks so you will need to fit new bottle cage boses etc, So unless its a brand new frame thats fresh off the press its not going to turn out to be great job,
Best best is to get a good wet or powder coat paint job
Posted : 16/02/2010 6:30 pm
looked at it recently and concluded what jd said.
Posted : 16/02/2010 6:33 pm
damn i wanted to get my old nicolai stripped and coated, will just have to stick to white now
Posted : 16/02/2010 6:45 pm
