I've got a XS Fire Mountain that I'm doing up for my son. I need some 165mm cranks for it, but they seem very expensive to me.
I'm after spare taper or external, 1, 2 or 3 rings in an easily replacable bolt spacing.
Is there anything out there for less than £50? I can't find much...
Thanks for any help!
Secondhand Zee?
I just got some square taper 155 mm for my SiL. £50 ish I think from SJS cycles. They've got various size options including, I would imagine, 165 mm. Nothing fancy and they're pretty weighty but they tick all the boxes.
aas above sjs have a few options
Thanks folks. Both options look good.
Those SPA ones are probably a bit lighter than the Thorn ones would you think?
if you're going square taper, you can go shorter than 165...
(inside-leg divided by 5, as a rough guide. My 5foot wife uses 140's)
Thicker pedals?
Alivio T4060 from CRC, external cups/hollow BB axle, not too heavy if converting to single ring... £40 and sell the rings on ebay. Just be warned - it's not a looker!
Not sure if 152mm is too short? Cranks are fine, chain rings are heavy, ideal for a 1x conversion.
Thicker pedals
Pedal thickness doesn't affect the 'throw' of the cranks.
XT double in 165 without BB are £77 at CRC. JAN17 for another 10 off probably.
More than 50 but bloody cheap.
@downshift - I'm not sure if those rings are removable. I think the rings are rivet on. Also may have an odd BCD
what length are your son's legs? you might find 165 could be too long.
http://highpath.co.uk/crank-length-calculation/
I have 2 sets of those suntours on kids bikes, rings are removable.
Yep std 104, have superstar 30t Nw rings on our girls bikes (there's a previous thread or 2 on them)...
@nre - thanks for the info. I've just ordered a set for my daughters bike 😀
You'll need a chain for it to work TBH
Just bought a set of [url= http://www.tartybikes.co.uk/cranksets/trialtech_race_square_taper_24t_crankset/c11p10079.html ]these[/url] for my fat bike. 162mm long, square taper, 4 bolt - lighter than the Suntour cranks they replaced - fitted a Renthal narrow-wide chainring and sold the bashguard on for a tenner 🙂
[img]
[/img]
