I need a washer with a 10mm internal diameter and a 14mm external dianeter which s about 2mm thick. Any ideas where i could find two? Preferably in stainless steel as its for the suspension on my giant reign. Ive looked online and been to some fastner places but havent found anything
bit of an odd size that mate, i have got tonnes of washers as i own a steel fab company, i got loads of 10mm internal but they are 20mm od. i would be happy to send you a few different ones if you want.
The size you want would only be 2mm widein 2mm material, not sure there is such a thing
Ring around some fabricators/metal workers to someone with some 14mm Stainless bar stock.
Get them to make a couple.
If it's for your suspension try someone like BETD, they might have something.
That's the size I have redhouse but thanks for the offer. Seems a very odd size. Only thing I have found which is that size is a spring washer but don't think that would work?
Ill email betd now and see what they say
i could make you some, but it's not going to be a tenner because stainless is quite expensive, and tricky to machine.
I can sort you out for not a lot. cwhitcombe at gmail dot com
How soon do you want them?
I don't mind pay paling some money to someone if they can make me some. Ideally id like them yesterday!!
I can do a couple of Au ones and stick them in the post first class if it helps (tough I dunno how fast post is going to be). Need to have a rummage for some stainless steel though.
Where are you?
I'm in the west midlands near to stourbridge
YGM
Be good to know a source for odd washers/bolts/etc (...and not where you can only buy 100+ at a time!). Trying to find washers for my FS frame was a pain...think I ended up buying from a RC car company
Could you drill out an M8 washer? i have one in front of me and the external measures 15mm (get the file out). may do as a temporary fix.
I'm in stourbridge myself and have loads if you need some. I can drill some out at dinner time if you want too.
Andy
Have you tried Hayley Bearings in Halesowen. They had some obscure bushings I needed for my Spicy the other week.
I just found some stainless bar. Tenner plus post if you still need them? You can pick them up from essex in 30mins. Let me know, email in profile.
Already posted him some. ๐
ah, good stuff. i can go home then!
Cheers k and thanks for all the help peeps ๐
Sometimes this place is ace. ๐
