Where can I buy spa...
[Closed] Where can I buy spare pinch bolts for HT2 cranks?
CRC don't appear to stock them
Posted : 27/01/2011 6:11 pm
Its just a standard M6 bolt IIRC. Shimano ones are slightly too short anyway..
Posted : 27/01/2011 6:13 pm
Get some nice long ones, which thread all the way down. Cut to size if necessary.
Posted : 27/01/2011 6:16 pm
Where from?
Local DIY shop, or Screwfix etc
Posted : 27/01/2011 6:18 pm
Ta
Posted : 27/01/2011 6:19 pm
Just make sure to reuse the washers, or find some new ones.
Posted : 27/01/2011 6:21 pm
Same size as brake mount bolts, I think. If you have a couple of those lying around.
Posted : 27/01/2011 6:22 pm
Thanks again - thought brake bolts were bigger? I'll check
Posted : 27/01/2011 6:27 pm
M6 - same as canti boss bolts, disc brake mount bolts, steerer cap bolts and many others.
Posted : 27/01/2011 6:32 pm
Great, thanks very much, I'll search the parts draw then use the links above !
Posted : 27/01/2011 6:40 pm
OOOOOH same as Canti bolts you say? I've got some nice SS one that would look better than the STD ones I have on there ATM.
Posted : 27/01/2011 6:55 pm
I found the size of the head on standard M6 bolts marginally too big compared to original bolts and had to file the outer down a bit.
Posted : 27/01/2011 8:13 pm
mtbtomo ain't wrong-m6 thread but smaller head size.
Posted : 27/01/2011 8:18 pm
