WHEN ARE SHIMANO GO...
[Closed] WHEN ARE SHIMANO GOING TO DO SOME NEW RAPID RISE REAR MECHS !
[#5685624]
[url= https://www.change.org/petitions/shimano-produce-some-new-rapid-rise-mechs ]Petition Link[/url]
Posted : 12/11/2013 2:04 pm
I'll pass, but thanks anyway.
Posted : 12/11/2013 2:12 pm
FFS - doesn't look like the chap behind it has even moved on to shadow mechs.
Posted : 12/11/2013 2:15 pm
I thought the answer was... they're not.
Just like they're not going to make any more Dual Control brake levers.
Posted : 12/11/2013 2:23 pm
I've got a couple of RR mechs I want to try soon, both XT ones. A friend of mine swears by them and I can see the advantage so I am RR curious!
Posted : 12/11/2013 2:27 pm
You serious?
Posted : 12/11/2013 2:29 pm
see they still live ! 🙂
Posted : 12/11/2013 2:31 pm
There are loads on ebay for a few quid each cos nobody wants them
Posted : 12/11/2013 2:32 pm
Still using RR on one bike, but I think Shimano have given up on it.
Shadow+ is brilliant... just relearn and switch if you have to.
Posted : 12/11/2013 2:33 pm
RR and flippies on my geared bike.
It's ace.
I've a small collection of mechs in storage.
Posted : 12/11/2013 2:35 pm
I switched to SRAM years ago, but has RR before that and loved it.
Posted : 12/11/2013 2:45 pm
Rapid rise is so much better for off road riding I have no idea why anyone would think it isn't. The only disadvantage I can see is getting used to it. Shame they dropped it.
So far as I know there's no more than 5 people on Earth who actually ever wanted "Rapid Rise" shifting, strictly speaking these backwards shifting oddballs should be shouted down, it was a technical/marketing dead end, get over it...
Don't think a petition is really warranted.
That said I really want to try a RR/Gripshift combo out, just to see what such a back to front twist shifting setup would be like... Then I'd probably take it all apart and go back to proper shifting like what normal people have...
Posted : 12/11/2013 2:53 pm
I have M953 and an M970 rear mechs in the garage that are perfectly good apart from the lack of jockey wheels.
RR is ace, just a shame that the Shadow design makes it hard to pull off.
Posted : 12/11/2013 2:54 pm
 D0NK
no there aren't.
Posted : 12/11/2013 2:55 pm
RR are ace. I am a convert.
Even better, here and pinkbike are a source of RR XT/XTR mechs for not a lot.... 8)
Posted : 12/11/2013 3:00 pm
 Leku
alot
Posted : 12/11/2013 3:03 pm
I loved RR.
My new frame needs a shadow mech for the cable routing though.
I now have one bike RR and one not and it's doing my head in.
So I'll shortly have two XTR RR mechs for sale plus an LX one 🙁
Posted : 12/11/2013 3:07 pm
I had one RR mech - it sort of made sense - was easy to grab a lower gear when you needed one suddenly, and you're always pedalling strongly and probably on the flat/downhill when you need a higher gear, so the "harder" shift was smoothed a bit. I guess that was the theory, I didn't go searching for another when it was time to replace, though.
Posted : 12/11/2013 3:08 pm
yeah are old Rapid Rise Mechs about but I want a new one with all that Shadow/Better Cabling/Clutch malarkey the new ones have.
Posted : 12/11/2013 3:10 pm
PS everyone who said they want one sign the petition we need to start some where.
Posted : 12/11/2013 3:11 pm
RR mechs rock, mind you I did have to change all my bikes over after I'd bought the first one by mistake - so not that much of a bargain then 😳
Posted : 12/11/2013 3:12 pm
And I want a 10 speed one which works with the new shifter with out any hacks
Posted : 12/11/2013 3:15 pm
IT'S NEVER GOING TO HAPPEN! MOVE ON.
Posted : 12/11/2013 3:19 pm
NO !
Posted : 12/11/2013 3:21 pm
At least the petition will serve a useful function in identifying these oddities who think they're good!
Posted : 12/11/2013 3:26 pm
Yup having the chain move up to an easier gear under load is a mad idea!
Posted : 12/11/2013 3:47 pm
rapid rise and gripshift user here.
Thing with RR mechs is that they just don't wear as quickly as the high normal mechs. (IME obv.)
I recently changed my M951 as the cage bolt wore out and became wobbly. The rest of the mech is in my spares box. Changed it for a M960, cheap off ebay.
so, a 15 year old mech dies, replaced by a 8 year old mech. still life in the old stuff. 🙂
Posted : 12/11/2013 3:56 pm
Would be good if the mech spring was 2-position so you could do either. I'd use RR on a road bike.
Posted : 12/11/2013 3:58 pm
I liked RR, it just seemed to work better in the real world where shifting is rarely perfect and you don't remember to ease it accross gentlty.
Probably wouldnt work with a clutch though as that already slows the downshifts. Or it would need either;
a) much stronger spring
b) a cluch that sensed the gear change, eased off the chain tension, then locked again when the next gear engaged. Would either mean 2 lots of indexing, or rolhof style indexing in the mech.
I give it one more revision before XT becomes a pinion style gearbox, with XTR remaining as chains/cassette/mechs for max efficiency on race bikes and <SLX the cheep dereilieur option. A bit like Ultegra getting hydraulic Di2 rather than Dura Ace.
Posted : 12/11/2013 4:07 pm
 D0NK
can't see it myself, shimano already do a seperate hubgear range.
not sure what you mean there
Posted : 12/11/2013 4:11 pm
The Hydraulic Di2 is a non-series part, neither Dura Ace or Ultegra.
Posted : 12/11/2013 5:14 pm
Precicely, so how long before they stick it up front in a pinion style box?
I meant, typicaly the second tier groupset usualy gets the utilitarian upgrades first, like the original XT disk brakes. Whereas XTR/DA get the lightweight or race orientated upgrades first.
You seem more pedantic than the entire bike industry which seems to have called it ultegra (google: di2 hydraulic, every result on the first page calls it ultegra, or ultegra level), even shimano gave it a 78x part number, and its release shortly after the 78xx groupset.
Posted : 12/11/2013 5:36 pm
Shimano decided not to release this under the Ultegra name as the lever was more bulky than standard Di2 or even mechanical shifters. Lars VDH was seen using prototype (all machined aluminium) Di2 levers at a race a week or so ago, with a profile bearing greater similarity to the regular Di2 levers. I imagine these will become part of a named group.
Posted : 12/11/2013 6:18 pm
 D0NK
ah right I was not aware that DA didn't have a hydro Di2 shifter. Makes sense now.
Still reckon we got a bit to go before pinion, mind you, how often are the groups updated? 4years? Was XT last year? So 6 or 7 years time for your theory, hmm...
Was about to ask would shimano really introduce di2 (which I reckon next XT will have) and then dump it for the next iteration? But then I remembered, this is the bike industry, of course they would.
Posted : 13/11/2013 10:23 am
All my mountain bikes are Rapid Rise. Always felt just right from the first time I used it (no flappy paddles here).
It's definitely put me off going 10-speed so far, so it must have cost Shimano at least £50 in lost sales. They must be struggling.
Posted : 13/11/2013 10:32 am
I want 10 speed flapy paddle snifters, only reason im still on 9 speed.
Posted : 13/11/2013 5:36 pm
I really liked the RR set up I had a few years back. Only changed because I bought a new bike without it. It was the only brand new XTR set up I've had though so I was never quite sure if it was the RR part that was ace or the XTRness. Changing up easily under load = sense to me.
Out of interest, do those who say it's sh*t have any reason apart from 'it shifts the wrong way'? Also, have they all used it for a decent period of time?
Posted : 13/11/2013 5:47 pm
 juan
My 1998 RR XTR is still going strong. All my MTB have RR mech. And I have one spare looking for one more spare.
Posted : 13/11/2013 5:55 pm
Is rapid rise the one where you can't brake and down change at the same time?
Posted : 13/11/2013 6:51 pm
Yeah, do it - it's good !
Ultegra flat bar 10sp lever works fine 😀 (Oh, hang on - you mean flappy brake levers ? (dual control ?))
No, that's dyspraxia
Posted : 13/11/2013 7:02 pm
Talk me through the process.
Posted : 13/11/2013 7:16 pm
[edited, didn't read intervening comments]
Posted : 13/11/2013 7:33 pm
I want the same rapid rise I had when I was 16 🙂
Posted : 13/11/2013 7:50 pm
The spring on the mech pulls it the other way - ie lower gear ratio not higher gear at the rear.
I use standard shimano shifters - just the rear shifter now works 'other way round'.
They shift down gear (as you start to go uphill) more 'naturally' as the spring 'waits' for you to just ease off pedal power a smidge and [b]shifts quickly without cable drag to slow it. [/b] <- that is noticeably better.
Posted : 13/11/2013 7:57 pm
