I know one is black and one is silver but there appears to be bigger all difference in price or weight.
I've heard some suggestion that the 42 on X01 is steel but some say not, and given the weight difference, it seems unlikely.
Does one wear better than the other? Resist corrosion better? Smell better?
X01 looks shit in no time because the anodising wears off. XX1 for me. 42t is alu on both.
Both are all alloy.
Both are anodised
One is black, one isn't..
Both cassettes are 11 > 2 Steel, 1 Alu. Both are basically the same. The difference is the surface treatment. The X01 is Black Oxide 11>2 and anodised 1 cog. XX1 I believe is plated with something else to make it wear better and shift smoother... like the top end chains.
Humm, hardly seems worth the "savings" of x01 once you're in that deep. Cheers all.
Yes sorry, not anodised as they're steel. Same point though - X01 ones look dreadful in no time. There's only a few pounds in it anyway.
you can replace a worn out 42t cog on the xx1 but you cant on the x01.. The x01 also wears faster than the xx1..
What if the xx1 was £200 and the x01 was £150?
Specifications for XG-1199 X-DOME™ Cassette
TECHNOLOGY HIGHLIGHT(S) X-DOME™, XD™ DRIVER BODY
WEIGHT 268g
MATERIAL 4130 chromoly steel (cog cluster), AL-7075-T6 (largest cog)
GEAR RATIOS 10-42t
SPEEDS 11-speed
RECOMMENDED CHAIN PC-XX1
RECOMMENDED GROUP SRAM XX1
COGS 10-12-14-16-18-21-24-28-32-36-42
COMPATIBILITY XD™ driver body
RETAIL AVAILABILITY July 2012
vs
Specifications for XG-1195 X-DOME™ Cassette
TECHNOLOGY HIGHLIGHT(S) X-DOME™, XD™ DRIVER BODY, JET™
WEIGHT 268g
GEAR RATIOS 10-42t
SPEEDS 11-speed
RECOMMENDED GROUP SRAM XX1, SRAM X01
COMPATIBILITY XD™ Driver Body
RETAIL AVAILABILITY June 2013
Not much difference, I've got the pinned version which is a significant saving and only a little bit heavier (about 100g lighter than XT)
