Just got a second hand set of juicy3's quite cheap however the rear appears to have a problem piston and i can't lever the pads apart.
Have managed to scratch the caliper up in the process so won't be able to send it back.
Whats the going rate for a lbs to sort this? (have tried screwdriver/pliers etc... with no luck)
Posted : 28/02/2010 7:50 pm
IIRC, piston & seal kit for juicy's is around £10-11 plus the labour & drop of fluid, so £20-30 depending on the shop I would've thought
Posted : 28/02/2010 7:52 pm
Or, check out the Piston & Seal kit from CRC [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=11972 ]here[/url] and then read how to do the job in the review section immediately below.
Posted : 28/02/2010 7:59 pm
