whats the best thin...
[Closed] whats the best thing to cut brakes hoses?
No I am not trying to sabotage someone, Ive just never bothered trimming my brake hoses from the stock length that they came with and my rear hose has enough length for 2 bikes!!
So I have Avid elixir CR's, I have the avid bleed kit, but I dont have the tools to snip the hoses and I am also lacking in another major factor.. the bottle to do it!!,
What is the worst that can happen? The LBs wants to charge me £35 to shorten them so i thought I would have a go first. I can always stump up the £35 if I balls it up.
Any guidance on the procedure and necessary tools appreciated
Posted : 29/10/2009 10:57 am
I used a new stanley knife blade (won't work on braided hoses, clearly!) and ran it around the hose rather than just trying to cut straight through.
Posted : 29/10/2009 11:01 am
Any sharp knife will do it - I often use a very sharp wood chisel
Posted : 29/10/2009 11:02 am
Dont the hoses have some kind of metal interior and does a stanley go through that OK?
Posted : 29/10/2009 11:03 am
Just use a Stanley knife and take your time. As long as you get a nice straight cut you're fine. If you've got the avid bleed kit then it really is a piece of piss to do. If you trim at the lever end you may get away without bleeding them anyway - as long as you don't spill all the brake fluid on the floor. Go to (ahem) Bikeradar (ahem) and download their avid bleed guide as it's better than the one on the SRAM website.
Posted : 29/10/2009 11:04 am
I use one of these...
...not for braided hose though.
Posted : 29/10/2009 11:06 am
run up + samurai sword. or a stanley blade.
Posted : 29/10/2009 11:07 am
 Olly
the best thing to cut brake hoses with is a brake hose cutter.
but a fresh, sharp as hell stanley knife works well.
nice square, clean cut.
braided hoses are have a metal jacket, but inside they are normal, and normal hoses are just fabricy kevlary stuff....
The [url= http://www.dotbike.com/ProductsP5477.aspx?utm_source%3dinternal%26utm_medium%3dsite%26utm_campaign%3dDFR ]A2Z hose cutter[/url] is only a tenner. The [url= http://www.dotbike.com/ProductsP601.aspx?utm_source%3dinternal%26utm_medium%3dsite%26utm_campaign%3dDFR ]Avid bleed kit[/url] costs more than your LBS is charging, but I'm sure the collected wisdom here will have a cheaper option.
Posted : 29/10/2009 11:11 am
I just used cable cutters - worked fine.
Buy some cable cutters for about £10. You can then also use them next time you want to cut gear cables and outers
Posted : 29/10/2009 11:27 am
The brake fluid thats left in the syringes, can that go back in the bottle or does it get binned?
Is my best bet to trim the hose at the lever end, re-attach, then bleed, or do I bleed 1st?
Posted : 29/10/2009 11:33 am
Last job - bleed
Posted : 29/10/2009 11:34 am
it does work fine!
I tried a Park cable cutter and it made a right mess of it 🙁
Posted : 29/10/2009 11:45 am
 D0NK
£35 bloody hell! Is that normal or is this LBS overcharging?
I have done it myself can't remember what I used to cut the hose, probably a knife - sure it took me less than an hour, a professional should be able to do it much quicker and there's no parts needed (maybe an olive?) so that price sounds steep. Pretty easy to do, may take a few goes, just remember to remove pads so they don't get contaminated.
Posted : 29/10/2009 11:50 am
remove the pads? I thought you just shoved in the red pad spacer thingy?
Posted : 29/10/2009 12:14 pm
 D0NK
You can do if you have one and you're neat and don't get DOT everywhere. I remove them and bung a 10mm allen key in there.
Posted : 29/10/2009 1:33 pm
The A2Z hose cutter is only a tenner
or only a couple of quid at your local PC parts shop
Posted : 29/10/2009 2:00 pm
is it a common thing to have to cut down hoses? the front one on my elixirs is huuuuuge!
Posted : 29/10/2009 2:31 pm
I always cut hoses to fit rather than leaving them long
Posted : 29/10/2009 2:33 pm
What's wrong with a sharp knife?
A disgruntled ex-wife has been known to do the job for free! 😉
Posted : 29/10/2009 2:44 pm
