Well my cheapo FSA one has worn and the chain is slipping badly; can't put any power down without it slipping.
Is it worth buying something like a Surly stainless steel one? Will it last a lot longer?
What other chainrings last for a decent while if SSing? TBH the FSA was only a temporary replacement but has lasted pretty well. Think it was a Middleburn or something previously; that lasted ages.
Ooh Renthal!!
It's forty pounds though. Is it worth it?
I've always used Surly. When the chain is .75 worn, I replace the chain and reverse mount the chainring and cog - last for ages
These ones
Steel and laste for ever..
No competition !!!
[url= http://www.homebrewedcomponents.com/store.php/categories/titanium-chainrings ]Homebrewed Components[/url]
I thought Titanium chainrings wore down very quickly..
Have heard that about cassettes
Surly are the ones to go for
I'm not spending all that money on a Ti ring. Don't be daft.
But please feel free to argue on this thread, in fact I positively encourage it. 🙂
This chainring is the best
[i]No, this one is and you're a moron![/i]
[b]No, [i]you're[/i] a moron so shut up![/b]
You smell!
Oh, and preferably 5-bolt 94mmBCD pattern, although I spose I could utilise a 4-bolt crank I have in my spares box.
On-One stainless steel, £25
Salsa last very well for alloy
Surly wear incredibley well, but dont like being bashed on logs
Renthal look lovely, and you can wear them as medalions when they wear out.
FSA are cheap, look great, work well, but wont last forever.
If your chain is slipping... do you need to adjust your tensioner?
Give me a call or email if you get stuck... here to help.
[url= http://www.charliethebikemonger.com/104-bcd-4-arm-20-c.asp ]linky linky[/url]
Charlie
my on one stainless has been going for an age and haven't had to reverse it yet....cheap and hard as nails..
That's a thought. I'm using a Surly Singulator on a regular geared frame. TBH there isn't a great deal of tension in the spring, but that's cos Singulators are crap imo as it's impossible to do the cheese-like springs up to provide enough tension on the chain. Chainline is fine.
Tried new cog, new chain so must be the chainring, no? It does look a bit worn.
I'd say Surly too.
I generally use Surly F&R, and they seem to last ages.
turn the ring around and see if that works, if its not ramped and pinned then should be ok.
I also rate the surly however they are finicky on what chain you use, e.g they have issues with 9 speed.
I also have a salsa which is lighter and is lasting very well, so that would be my recommendation.
fwiw i also have an fsa which works fine, and is cheaper than all the above.
have a 32h Renthal (1 month old) tis super 😀
for power and performance Rotor Q ring, for longevity surly stainless steel, for ultimate bling a boone Ti
how's the Q Ring going tazzy?
stu has my spare one that's doing the demo rounds I can get him to send it on to you if you fancy a go.
My 34 SS specific is fantastic and has been top banana for some very fast and consistent lap times.
There may be some more cost effective versions available soon via some very nice CNC machining chappies. I should be testing one soon and i'll let you know prices, but should be less than £40.00
Er excuse me Tazzy; this is [i]my[/i] thread about [i]my[/i] SS chainring dilemma. So don't be trying to hi-jack it with your tales of funny shaped rings please. 😯
So rude... 😐
Stainless last loads longer than alu?
well my dear elf, if you want your little pointy shoes to spin faster for further you'll listen to your great uncle taz as he knows bestest and his ring collection is more mishapen than goatse 😆
Chuzz, I have a 32t FSA in my spares box if you want? 😀
[url= http://www.mountainbikecomponents.co.uk/items.asp?CategoryID=32&Name=Goldtec+1%2F8th+Track+and+Single+Speed+Chainrings ]£25[/url]
Yes pliz Andy fankyoo!
And so, comes Great Joy.
😆 xx
mine has but you can get some thicker SS DH specific alu ones which are prety hard wearing too and a bit lighter than steel, but steel probably lasts longer as its harder isnt it
"... more cost effective versions available soon"
interested in this.. keep us posted.. thank you.
Yep - let us know 😀
This is nice if you can find one 😀
[url= http://farm7.static.flickr.com/6014/5880962522_c0ae486480_z.jp g" target="_blank">http://farm7.static.flickr.com/6014/5880962522_c0ae486480_z.jp g"/> [/img][/url]
[url=
[/url] by [url= http://www.flickr.com/people/32746168@N08/ ]ten_sim[/url], on Flickr
Could I find one in your spares box Psychle?
Give to me it please.
Took me 2 years to secure that one Mr Elf... stupid rare things they are, pointless too, no better than a £20 chainring really, wanted one just for the bling of it tbh 😳 8)
[url= http://www.velosolo.co.uk/shopcrank.html ]here[/url] I use the gebhardt one at £21.95. loves em.
toys19 has the right idea 🙂
[url= http://velosolo.co.uk/shopcrank.html ]Velosolo[/url] are not that well known, but well worth a look. I use their chainrings these days and they last well without being as heavy as Surly.
Surly Stainless, won't flinch at buying another. 4 years old, only thrown the chain once or twice (when I let things slip a little) and still no obvious signs of wear.
Forget the weight penalty (!) won't really matter with all the stuff you probably cram in your Camelbak.
I have a Pauls comp one that just won't die bit you need the cranks as well
Surly, On-one and Salsa, all good. Sometimes they will last 6 months if I'm lucky. Not found any better.
Six months?? I want it to last six [i]years[/i], not six flippin' months!! 😯
Surly or On-One steel ones winning at the moment, it's got to be said.
Middleburn one lasted about 2 years. FSA one about a year. So about roughly the same sort of 'value', as the FSA one was about half the price of the Middleburn.
Get the Surly because the On-one doesn't come in 5 bolt. I've been running one for at least 3 years. It's been bent right over in a nasty chain-dropping incident, and trued several times after heavy rock/step strikes, and it still looks only lightly worn. It'll last for 20+ chain changes I reckon.
i've got a Renthal, it's lovely but i did get it for £20 in a sale
[url= http://farm5.static.flickr.com/4107/5063008616_da86514d39_b.jp g" target="_blank">http://farm5.static.flickr.com/4107/5063008616_da86514d39_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/5063008616/ ]Renthal + N-Stop[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
On-One from my point of view - a previous Inbred SS had one and after 2 years of grime/slop/general hamfistedness I'd still not killed it. Pretty hooked by then, mind you.
On-one stainless vote here. It's had a load of grief from me over a couple of years and still as good as new. You know it mkaes sense.
just bought a 36t middleburn one for a tenner off classifeds. it's not a proper ss one or nowt but'll get me to the pub/shops/work 🙂
I'd avoid the Renthall.
I've tried:
[b]Salsa[/b] - lasted ages,trouble-free.
[b]Cycle Dynamics (Ti)[/b] - lasted ages, trouble-free.
[b]Thorn[/b] - lasted ages,trouble-free.
[b]Renthall[/b] - constant aggro. Chainring bolts kept undoing themselves, chain dropped as a result, teeth chewed up. Tried numerous different bolts of different lengths and they all needed tightening daily to keep it working. Same cranks (XT HT2) and bolts had no problems with any of the other rings.
As for a tensioner, I've got a Yess ETR-V and Rohloff going spare, either of which would be fine, but anything else sprung seems designed to fail. Currently running a DMR Tension Seeker which sought tension and failed to find it, so it's now held in place with a thick zip tie. Can't get the right chainline with either the Rohloff or Yess (as running a big ring) otherwise I'd use one of those.
renthal all the way surely..?!
[b]it's what they do fer gawds sake..[/b]
..and I find it's always good to follow sound practical advice based on personal experience with a heartfelt post based purely on romanticism and emotion..
I run 1x9 on both mountain bikes - MRP (alloy) is good. Lovely and light. 7 months old and hardly any visible wear on the anodising which seems pretty good going.
On-One SS is about the same age and still looks brand spankers. Noticeably heavier than the MRP but suspect it'll last forever. Cheap too (got mine when they were £20 earlier in the year) but like someone said, 4-bolt only.
I think I'm gonna have to dig out those Deore 4-bolt cranks as there are hardly any decent 5-bolt chainrings around. 😥
Such a shame. Was running some lovely old Cannondale cranks which are really stiff and light.
