What's going o...
[Closed] What's going on with the fork/crownrace on this?
http://www.ebay.co.uk/itm/SALSA-MAMASITA-29ER-MOUNTAIN-BIKE-ROCKSHOX-SID-XT-19-FRAME-RACEFACE-XT-BRAKES-/231392160052?pt=UK_Bikes_GL&hash=item35e00c2934
Looks like a tapered fork with a non tapered head tube.
But it can't be.
But it does look odd.
Whassup with it?
Posted : 12/12/2014 8:36 pm
And why so many photos that are hardly any different?
It does indeed look to me as though it's a conventional 1 1/8th head tube with a tapered fork and the black ring you see between the crown of the fork and the bottom of the head tube is a black bearing which is kind of sitting into the bottom of the head tube as it has a chamfer on it that would normally sit in the lower headset cup.
ie death trap!
Posted : 12/12/2014 8:41 pm
He's got really good feedback though, and looks like he trades a lot of cycling stuff.... I can't work it out
Posted : 12/12/2014 8:43 pm
I knew I had seen black headset bearings somewhere: http://www.ebay.co.uk/itm/Cane-Creek-Headset-Bearing-1-5-52-mm-CBAA0006K-/131374263267?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item1e96842be3
edit: saw it was a shop. Worth emailing him? Ask him if he'll do you a deal on the forks ๐Ÿ˜€
Posted : 12/12/2014 8:45 pm
either an external 1.5 lower cup or maybe a refitted steerer (if they can still do that) ?
You won't be able to refit a steerer and that doesnt look like a lower cup to me.
Posted : 12/12/2014 8:46 pm
OEM fork to aesthetically fit a frame with a 44mm head tube (but 1 1/8th straight steerer).
Mate mas a similar set up.
Looks terrible.
Posted : 12/12/2014 8:52 pm
dbl pst, srry
I think this is the same frame and there's definitely(?) something more below the ebay headtube than this one
[url] .html[/url]
*changes mind - nothing extra underneath. must have a normal steerer and [b][i]is[/i][/b] pretty fugly*
Posted : 12/12/2014 8:53 pm
I think it's legit. The black Crank Bros headsets do indeed look just like a single sealed bearing (I've fitted a few in the past) - the bottom cup fitted to a Mamasita (which appears to have an externally butted headtube), may give the appearance of a visible sealed bearing. Does that version of the Mamasita have a standard 1 1/8" head tube?
Posted : 12/12/2014 8:59 pm
edit: this is a crank bros:
Does look familiar but the fork definitely looks tapered and too big.
Posted : 12/12/2014 9:00 pm
Definitely a normal Crank Bros headset, like I used to have:
Like sillyoldman says, it's probably a weird OEM fork with a 1 1/8 steerer for a large headtube.
Posted : 12/12/2014 9:12 pm
1.5" lower bearing definitely won't even get close to an old style head tube. Must be a Crank Bros headset, top looks similar and has a blue ring which looks like a crank brothers feature.
Stumped and only thing could be oversize crown with 1 1/8th steerer.
Posted : 12/12/2014 9:13 pm
I had a CB headset on my Soul for a few weeks before it rusted - the skinny headtube and tiny lower cup looked all out of proportion with the fork crown
Posted : 12/12/2014 9:22 pm
Maybe the headset came without a crown race. Is that unusual? ๐Ÿ˜‰
Posted : 12/12/2014 9:34 pm
I dunno wtf is going on with that steerer/headset but if I were hoping to sell that as a bike trader, I'd better take better actual detailed close up photos.
Posted : 12/12/2014 10:01 pm
