I now have a tool board so would like some long tyre levers that I can hang up.
Park do some large metal ones, have a pair in my tool box, look a bit evil for most jobs though. Generally I don't use tyre levers as I've developed the technique for working the tyres on and off without the need
Does anyone make a tyre lever that has an audible alarm or light when you are about to kill a tube while trying to remove a tyre?
You'll never guess what I did yesterday, again... 😯
[url= http://www.chainreactioncycles.com/x-tools-plastic-tyre-levers-set-long/rp-prod122316 ]quite long, cheap, dont break and have a hole in them for peg board display thing[/url]
For a workshop tool, the Kool Stop Bead Jack / Tyre Mate can be very useful. It makes it much easier to fit tight tyres, without damaging the tube.
I like these, picked up a set at a bike show recently:
https://www.bikerumor.com/2016/11/28/clever-standard-makes-quick-work-re-using-chain-quick-links/
Pedros are as long as you need and the best available.
Pedros are alright. Lezyne powerlevers are quite a bit better though- the hook is thinner which makes everything easier especially with tight tyres. They're not long, but they do have a hole in the top so you can hang them up, and they cost about £3 for 2. Only downer is, they're not indestructible, I broke the tip off one fitting a tight dualply- but it cost £1.50 so, frankly I don't care.
