What to do with a c...
[Closed] What to do with a cracked frame?
Full suss has cracked beyond any repair so apart from selling the shock what can you do with the aluminium frame apart from leave it in the shed?
Posted : 13/09/2011 10:22 am
take it to the tip for recycling?
Personally, I'd be worried about sellign a cracked frame for fear someone will bodge it and sell it to some unsuspecting punter.
You might get something for the non cracked part and bearings?
Posted : 13/09/2011 10:23 am
pics please.
I do not believe in "unrepairable".
Posted : 13/09/2011 10:26 am
[i]I do not believe in "unrepairable". [/i]
where there's a spoon, there's a way ๐Ÿ˜‰
Posted : 13/09/2011 10:27 am
Make a wheel building/truing stand out of the rear end?
Posted : 13/09/2011 10:30 am
If you can't fix it with duct tape, you're not using enough duct tape
Posted : 13/09/2011 10:34 am
Don't really want to sell it as I think its unsafe. The bearing are on their last legs but the rear is fine although its a 2007 model and I doubt there will be much interest.
Goes all the way round until the reinforcing plate on the top of the top tube.
Posted : 13/09/2011 10:38 am
No idea if these are any good but Real Cycles are selling Commencal front ends on ebay;
[url= http://www.ebay.co.uk/sch/real-cycles/m.html?_nkw=&_armrs=1&_from=&_ipg=25&_trksid=p3686 ]http://www.ebay.co.uk/sch/real-cycles/m.html?_nkw=&_armrs=1&_from=&_ipg=25&_trksid=p3686[/url]
might be worth calling them to see if they have any others?
Posted : 13/09/2011 10:42 am
Already sorted a new frame.
Posted : 13/09/2011 10:46 am
A commencal!
Sell the rear end.
Mine cracked there too, but on the weld. But mine was still under warrenty.
Posted : 13/09/2011 10:47 am
if you can find a new front end it would at least give the back end some value to someone, even if you don't buy it yourself?
Posted : 13/09/2011 10:48 am
I would think that at worst you would be able to sell the shock and linkage plates, possibly chuck in the rear triangel in the sale of the linkage plates.
Then just take the front triangle to the skip or hang it up in the shead a a momento to your wikid gnar skilz bruv ๐Ÿ˜‰ or use it as a massive wind chime with some old sprokets hung off it to clater about ๐Ÿ™‚
Posted : 13/09/2011 10:50 am
Thanks, will try and sell the rear end and shock. Probably keep the front for the shed wall.
Posted : 13/09/2011 10:56 am
Call that a broken frame?
This is a broken frame ๐Ÿ˜ก
[url= http://farm6.static.flickr.com/5214/5468488463_730be351c8_b.jp g" target="_blank">http://farm6.static.flickr.com/5214/5468488463_730be351c8_b.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/5468488463/ ]brokenbike2[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Posted : 13/09/2011 10:59 am
