What suspension for...
[Closed] What suspension forks are you riding on your Singular Swifts?
I'm hoping to be getting a Swift frame soon and I'll be building it up with suspension at the front so what forks are people using - or more to the point, what travel? I'd be getting an XL which has a fairly long head tube (140mm) so I suspect that anything over 100mm might make it very high at the front.
This was me borrowing an XL Swift and it felt about right position-wise with the rigid fork, flat bar and stem with low rise so I'm thinking that even with a 100mm fork I might be having to run negative rise on the stem - it'll practically be a road bike 🙂
Posted : 10/06/2010 10:45 am
large size swift over here, similar riding position.
i'm thinking that a 80mm fork versus a rigid steel plus a big squishy tyre isn't enough of an improvment to justify the expenditure.
Posted : 10/06/2010 10:53 am
I'd disagree - even 80mm travel makes a big difference over a rigid fork and fat tyre - besides, I remember the days on the Judy DH when 75mm was considered huge 😉
Posted : 10/06/2010 10:56 am
yeah but £400/£500 worth of difference?
I'll probably still end up doing it, just wincing at the thought!
Posted : 10/06/2010 10:57 am
i'll post pics if/when they arrive 😉
you;ve dumped the viper idea then?
Posted : 10/06/2010 11:01 am
Use the standard rigid fork and put a 2.4 on the front instead. :mrgreen:
Posted : 10/06/2010 11:12 am
Well Sam made a good offer so if I can sell enough bits then it's a Singular...
Rocketdog - I downloaded a manual for your Manitous and while it's not how they're designed, I reckoned you could pretty easily modify them to run at 100mm
Posted : 10/06/2010 11:57 am
Kona unit frame, large with 135mm Headtube, similar to the swift XL headtube and similar head angle too)currently mated to a pair of Maz 44TST2 29ers at 120mm. Front end ok, might be a little high for some but once the fork has sagged, not a huge difference from a 470mm rigid exotics before
Posted : 10/06/2010 1:52 pm
I run rigid on my Inbred 29er, Reba 80mm on my Rockhopper 29er and 120mm Maxle Reba on my Salsa Big Mama.
80mm feels like more than enough for most of my riding, i would run the Reba maxles at 100mm but they came at 120 and i couldn't be bothered to pay somebody to reduce them for me.
Although rigid with 2.55" low PSI tyres is fine for most riding (esp. uphill and flat) you still feel it a lot on some of the downs and the 80mm makes a big difference imho.
It's just difficult to find cheap 29er forks (like Tora, Recon equivalents) so you have to start looking at £300+ unless you get lucky on the classifieds/ebay. I do regret selling my Tora 29ers for £110 to a chap off here now - they could go on the On One but i didn't own it at the time i sold them.
Got my forks in the states and shipped over and despite the fact my folks are there at the moment and could bring me back a set, my chappy over there could not source me any Reba SL's (i wanted basic ones) saying that it seems the supply is dry until the 2011 models start to come through.
Posted : 10/06/2010 2:16 pm
I've often thought that 80mm with the added 'roll-over' potential of the 29er wheel probably makes it as 'capable' as a 100mm forked 26er.
Heaven knows how much more 'capable' my 26er SS is running an 80mm fork over rigid ...
Posted : 10/06/2010 2:23 pm
slight tangent i spose but why is my swift so much easier to trackstand than my previous little bikes? tyres are a similar width, as are the bars... weird
Posted : 10/06/2010 2:41 pm
I rum the 80mm minutes on mine nice fork a bit of a faff to set up but now riding very nice
Fork geometry blessed by Sam,
also don't get too hung up on how much travel you think you need compared to 26" you will get away with less
Posted : 10/06/2010 10:32 pm
just fitted these 2010 suntour 100mm to a karate monkey, alloy stantions,steerer and 15mm through axle and there ace...and only £189 from chain reaction cycles...
[img]
Posted : 10/06/2010 10:42 pm
Are they really heavy? How well put together do they seem? Review?
Posted : 10/06/2010 10:46 pm
clubber - I ran my XL swift with 100mm Manitous up front and i really liked the riding position. I'm 6'5" and was using a 70mm Thomson stem with 35mm of spacers under it.
I asked at my lbs about changing the travel on minutes and was told that its not possible, CRC have some for £360 due in early July 😉
Good choice on the Swift btw, look forward to seeing the pics 😛
Posted : 10/06/2010 10:49 pm
Well you can always reduce the travel of air forks by extending the top out bumper but it can require some messing about with negative springs but I've done it a few times with various forks
Posted : 10/06/2010 10:52 pm
Ok they might have meant that it wasn't cost effective to do it then. I don't touch fork internals myself 😕
Posted : 10/06/2010 10:58 pm
I like the look of those Suntours - surprised that i've not seen anybody on here mention them before?
At that price i'd certainly give them a punt but only 15mm bolt thru available. I have a halo freedom 29er wheel knocking around as a spare but it's either QR or 20mm and it doesn't look like they do a 15mm adaptor kit. Bugger. 🙁
Typical, he first cheapo 29er fork that comes along to try and it's a bloody 15mm one. Seems strange that is the only offering they do.
Posted : 10/06/2010 11:48 pm
Nice to see clubber avoiding a 100 post thread by starting another one about another frame! 😀
Posted : 11/06/2010 7:12 am
Mr Tall, if your freedom wheel has the spin doctor hub then you can get these bad boys :
Use them on a pair of Marzocchi 44tst 29er forks, just the job for 15mm forks ! 🙄
Posted : 11/06/2010 7:43 am
does it sa "epicod" on those suntours? sounds fishy
Posted : 11/06/2010 8:09 am
Using 29er Reba Race 100mm dual air forks on my XL Swift. With about 20mm of spacers and some mid rise bars. Currently running with gears and it climbs steep hills in granny ring without the front lifting. The original rigid forks with a 2.35 tyre up front worked well enough most of the time. But it could get a bit 'exciting' on the fast, rough downhills in the summer. Now the limit is the fact that it is a hardtail......... still a great frame though......
Posted : 11/06/2010 8:19 am
Cheers Bunners,
I saw those on CRC but thought they seemed to be XTR specific so didn't think they'd fit. If they will i may well buy a set of the forks and give them a go on my SS. I guess for a tenner it's worth getting them to try.
Posted : 11/06/2010 8:26 am
Those are silly cheap - shame they're not Mud Xs.
At the moment, I'm a bit stuck - had agreed a sale of a load of bits but not the buyer's gone quiet so I don't know if he's actually going to buy them and therefore whether I'll actually have the cash for the Swift...
Suntour forks - hard to get over the name (more the reputation of quality or lack thereof rather than the name itself actually) but they do look tempting...
Posted : 11/06/2010 9:04 am
Shaggy was testing some Suntour forks last year (I don't know what model but they were cheap) and he seemed quite taken by them.
EDIT: Now I think about it it may have even been the year before.
Posted : 11/06/2010 9:09 am
Yeah, I had heard that - it's just a bit like Skoda isn't it - you hear that they're good now but it's hard to get over the previous reputation.
I think that unless I find some good second hand forks then I may well go for the Suntours so we'll see...
Posted : 11/06/2010 9:10 am
I heard Suntour actually manufactures forks for some of the big name brands.
Posted : 11/06/2010 9:15 am
That's spinner isn't it - they do the cheaper RS forks AFAIK.
Could be suntour too though I guess.
Posted : 11/06/2010 9:16 am
" I saw those on CRC but thought they seemed to be XTR specific so didn't think they'd fit. If they will i may well buy a set of the forks and give them a go on my SS. I guess for a tenner it's worth getting them to try."
Thats what I thought so I just got a pair and they work just fine on the 44 fork and spin doc hub, no reason why they wouldnt fit on any other 15mm bolt through fork 🙄
Posted : 11/06/2010 10:28 am
If anyone wants to sell me their Swift rigid fork, drop me a line!
Posted : 11/06/2010 11:11 am
Cool. May order some adaptors later and try them before i order a fork.
There are 3 29er Suntour forks on CRC - The Raidon and 2 versions of the Epicon. They all seem like the same fork (internally) but the Raidon has a black stanchions & steel steerer and the Epicons have Gold anodized Alloy Stanchions and alloy steerer. The one above in the pic appears to be the remote version.
The only difference i can see is that one has remote lockout and one has it on top of the fork leg. Seems strange that the remote version is £10 more than the non remote? A pain as i don't want the remote to clutter up my bars. Still at £200 they are in a league of there own price wise for 29er forks.
Anybody have a view on which one is best to get (and why the raidon is more expensive than one of the Epicons despite seeming like a cheaper & heavier fork)? Has anybody found any weight figures for them yet? Did you weigh yours before fitting Coastkid? Cheers.
Oops - i meant the remote lockout is £10 cheaper. Can't find weight details anywhere but the 26" version appears to weigh aroun 4lbs which is not too bad.
Posted : 11/06/2010 11:35 am
Anyone know what offset the Suntours have?
Posted : 11/06/2010 11:40 am
these:
i was looking at getting some forks for my swift. though now it seems Giant are going to release an Anthem 29er, might just put the cash towards a whole suspension bike and be done with it.
Posted : 11/06/2010 1:14 pm
Hi i will have these for sale in 2 weeks 2010 rockshox reba sl 29er black can be 80 or 100mm steerer is around 195mm only been used around 6 times 150 miles max £300 ono posted.
Posted : 11/06/2010 1:24 pm
Just bit the bullet and ordered some Epicons. Chap on here posted a voucher code for CRC so i only had to pay £180. 🙂
I'll let people know the weight etc after they turn up, hopfully on Monday.
Posted : 11/06/2010 2:27 pm
Suntour used to make OEM and cheap Marzocchis. They were awful. Not to say that these ones are, though.
It's worth bearing in mind, Dylan, that the rigid fork is *very* tall on the Swift - you'll not raise the bars much (if at all) running a 80mm fork, at least. And a 100mm one with sag will probably also be at a similar height.
BTW, if you do decide to lower some manitous to 100mm, be advised that I did the same thing to a pair of Rebas (took them down to 70-odd mm). It worked fine, except that I found they then had a very rising rate, and so were prone to superfast rebound on bigger hits.. so experiment with some thicker damping oil.
Posted : 11/06/2010 3:09 pm
They're only 1.5cm longer than standard 47cm forks though and the head tube is pretty long at 14cm...
Posted : 11/06/2010 3:29 pm
So, how are they, MrTall?
Posted : 14/06/2010 12:53 pm
Ordered Friday lunchtime and still 'processing'............ 🙁
Posted : 14/06/2010 1:08 pm
Dammit! Jack Bauer wouldn't have to put up with this ****! 😉
Posted : 14/06/2010 1:09 pm
While we're talking 29ers, anyone running a 2x9 on theirs? I've been using 24/36 and 11-34 on my 26" bike and thinking that 22/32 with the same 11-34 should be about right.
Posted : 14/06/2010 1:16 pm
CRC, all is forgiven. The nice postman has just delivered them to me. 🙂
Posted : 14/06/2010 1:17 pm
C'mon, a quick squish on the floor and you could do a full MBR review!
Posted : 14/06/2010 1:30 pm
They seem fine considering what they cost. Not quite as well finished as the Rockshox i have but that's to be expected. Feel fairly light although i have no scales at the office to weigh them - i'll do that later and post it up. The thru axle seems well made but i can't try it as yet because CRC didn't send the 15mm adaptors i ordered 2 hours before the forks!
All in all everything appears in order (although the lockout lever seemed to have come off in transit but then it popped straight back on).
I also have to wait for a spare raceface deus crown race before i try them and i'm having a nightmare sourcing one. Nobody seems to stock them except CRC and they are out of stock.
Posted : 14/06/2010 1:38 pm
Get the crown race you have (I assume that you want one frame with two sets of forks), cut a slot in it and then you can easily move the crown race between forks so you don't need a spare. I've done this for years on my and mates' bikes - never any problems.
(slight caveat - doesn't work for non-cartridge bearing headsets but these days that's quite uncommon except for very cheap ones).
Posted : 14/06/2010 1:53 pm
Just use a hacksaw to cut it or is there something better?
Posted : 14/06/2010 2:16 pm
Hacksaw's fine (ideally get a new blade to make sure it's neat).
Posted : 14/06/2010 2:17 pm
1920g with uncut 255mm steerer and including the Bolt Thru Axle.
1790g without the axle.
Reasonable weight i'd say, certainly for the cost.
Posted : 14/06/2010 6:59 pm
That's it, committed to buy the Singular now 🙂 Thanks Sam.
All I need to do is sell some other bits so that I can afford some forks for it 🙂
Posted : 15/06/2010 2:39 pm
That's it, committed to buy the Singular now Thanks Sam.
Does Cadel know that Father Christmas can't afford any presents for him this year now?
Posted : 15/06/2010 2:42 pm
Got anything decent to sell?
Indeed I do. Not to you though, you're a pain... 😉
It's mini-Clubber's birthday this week. He's too young to realise he's supposed to be getting presents which is lucky...
Posted : 15/06/2010 2:52 pm
Bad Daddy. [img]
Posted : 15/06/2010 2:54 pm
It's alright, I have actually got him the best present ever - his first bike 🙂
Posted : 15/06/2010 3:03 pm
A second hand singular Swift to be phased in about 15 years time?
Posted : 15/06/2010 3:05 pm
Got any spare *ahem* 29er tyres? :ohtheshame:
LOL - yeah, KT 🙂
Posted : 15/06/2010 3:08 pm
Shock news: man buys bike.
Posted : 15/06/2010 3:32 pm
Shock news: man buys Clown bike.
Fixed it for you.
Posted : 15/06/2010 3:33 pm
Cruel, very cruel.
**s****s**
Posted : 15/06/2010 3:35 pm
Posted : 15/06/2010 5:10 pm
clubber - Member
I hope its all the bike you want, enjoy!
Posted : 15/06/2010 6:02 pm
He'll only enjoy it if he doesn't like it!
Posted : 15/06/2010 6:51 pm
Yeah yeah 😉
Posted : 15/06/2010 6:53 pm
Mr Tall - Yep I'm running 2x9 on the Paradox 36-22 upfront and 11-32 out back, have considered other set ups but waiting till i need to replace the whole cassette/rear mech/chain for 2x10 when 9spd is phased out in 2011 😉
Oh and good choice on the Swift clubber, I'm sure jnr will understand 😛
Posted : 15/06/2010 7:09 pm
MrTall - ridden them yet? Reports
Posted : 18/06/2010 10:43 am
