So i'm looking to swap out the DRCV shock on the remedy to a Monarch Plus RC3 debonair.
But I have no idea which tune to get. An hour or so of googling and I am none the wiser, can anyone share some info on this? E.g. is there a specific tune for the remedy, or how do I calculate which tune would be best for me?
I'm interested to try getting the shock pushed, which would of course solve my problem, but I'm keen to try it stock first and see how it performs.
cheers
Not sure if it's the same as before but my old remedy needed a specific shock, ie a normal monarch wouldn't fit.
Take a look at how your DRCV is mounted......take a look at the Monarch etc....Different mounting.
I think you can get a PUSH kit for them and custom internals, but thats it?
You can adjust them with air volume spacers. You can also remove the push-rod that activates the second air chamber. This gives a little more ramp up.
A monarch will fit,it just needs different shock hardware (have a Google). I have a volume spacer installed, tinkerer with pressures etc but still am not too happy with it, more interested to understand how to calculate which tune works best, e.g. rockshox shocks are available in l/m/h compression and rebound tunes
Found this earlier, which is helpful (provided it is still accurate for the 2015/16 shocks):
Time to read up on rising and falling leverage rates later...
