What Rebound and Co...
[Closed] What Rebound and Compression tune for Pitch?
Can anyone point me in the right direction?
looking at a nice cheap rockshox kage for my 2008 Pitch but don't know where to find what tunes original shock would have come with.
Kage available with mid comp, mid rebound...
Posted : 23/09/2015 9:54 am
just give this a bump on the off chance anyone gives a crap : )
Posted : 24/09/2015 11:58 am
ok, looks like a firm comp tune from bikeradar review
but reviewer suggests changing to a "more open and fluid tune to maximise plushness" so mid comptune could be fine?
as for rebound tune, more research
this is great, i'm having a discussion with myself : )
Posted : 24/09/2015 12:06 pm
Mate of mine with a pitch put a volume reducer in his fox shock to prevent bottom out. Reckoned it improved it. Not sure if that helps you but he did say it was wallowy in it's original tune so maybe a firm tune would be better.
Why not contact tft or loco etc?
Posted : 24/09/2015 12:45 pm
thanks docrobster
not wallowy mine. have read about that but bottom out never a problem.
i guess i could reduce volume and the air pressure to see what it feels like. It's achly a bit harsh, tho still not bad.
Already pushed, and then later tuned by loco.
anyway, to cut a long story short, i just fancy giving coil a go
Posted : 24/09/2015 1:21 pm
I went from the normal to a high volume can, mostly to sort out the rebound. But then I'm 100kg so at the end of the normal curve.
I'd suggest getting a shock from TF or similar, may as well get a Van RC from them that works than a cheap Kage from elsewhere that then needs a tune.
Posted : 24/09/2015 1:48 pm
sure, i kinda agree, but i'm only considering cos i think it will be ok, can get a tune later, and is nice and cheap!
Posted : 24/09/2015 5:12 pm
I bought Thisisnotaspoon's Pitch.
The RP2 on it was marked on the air can as medium compression and low rebound.
The custom tune didn't work for me (I'm almost 30kg lighter). Rather than another custom tune I fitted a 2nd hand RP23 with medium rebound and compression which I find to work OK.
Posted : 24/09/2015 6:14 pm
ok great, thanks simon.
i'm same weight as you so sounds safe enough bet.
i think i bought it's original wheels : )
Posted : 24/09/2015 6:32 pm
MM will be fine.
A pitch, it is "rising rate" with a slight fall at the end to counteract air spring progressiveness. Nothing odd, nothing special required tuning wise. Just fit the firm bump stop to mimic the air spring progressiveness.
The overall LR isn't anything odd, (150/57=2.6), not high, not low.
Unless you're really heavy, it'll be great for it.
Posted : 24/09/2015 6:35 pm
magic, thanks dean!
now just have to weigh up the pennies, or centimes achly
Posted : 24/09/2015 6:53 pm
