Needs to be self contained
battery would be ace
2+ bikes capacity
Aware of Worx hydroshot which is my current "want" but spendy at £100
Worx is brilliant, well worth it IMO.
Easily does two bikes and takes up less space than the karcher.
anyone seen any deals on a worx?
+1 for worx, mines been ace. Combine it with a big water carrier in the back of the car for multiple bikes.
I got a "used" one from Amazon, it was a returned item but brand new and was about £76. Might be some offers on there at the moment
Worx is well worth the money.
no battery though
Worx user here too. Mine does 2 bikes properly, could probably stretch to a 3rd at a push. 2 3/4 buckets I can get out of the battery.
I'm going to get a water container to take with me soon so I can wash the bikes at the end of the ride rather than leaving them till it's light outside again 🙂
It's a lot better than the Mobi one I used to have.
Worx here too, very happy with it so far, it's been great
I just use a 7 litre pressure sprayer from screw fix, under a tenner, doesn't take batteries - just a wee bit pumping up by hand. Could probably do a couple of bikes in 1 fill. Could fill it up in a river if needed or carry extra water if more needed
I've had a couple of 12v ones before - the original Dirtworker (got nicked) and something more recent. Neither were great, whereas the Worx is worth every penny - would definitely buy again
came here to say the same as aide - better for the environment and less faff because they never run out of charge
worx it is then - need to find where cheapest now
I got a Mobi V15 as a Christmas present and I'm very pleased with it. It's not jet wash powerful but perfect for cleaning mud off the bike at this time of year. Holds 15 litres, just enough for two quite thorough washes and runs off a car 12V DC outlet. Seems well made and no leaks or drips.
Had the original dirt worker but upgraded to the worx hydroshot. 25l Jerry can of warm water and a spare battery. 3 bikes with ease and so much better than the dirt worker.
Has anyone tried using a Worx to wash a dog? I guess I'm asking can you turn the pressure right down to a gentle hose so I don't blast my dog's feet off?
I believe there are two models, one of which has two pressure settings which I think is for that sort of purpose.
To the Op. Another vote for the Worx. I was using a cheap 12v pump kit from EBay, which for 25 notes was amazing and worked brilliantly. The Worx however is way more convenient. You just have to remember to charge the battery.
I made a case for my eBay one.
You guys that have used the hydroshot and the eBay caravan pump types, what's the difference in pressure like between the two?
Sticky clay on tyres is pretty heavy on water use with my caravan pump spray. I'm wondering if the hydroshot is any better.
Has anyone tried using a Worx to wash a dog? I guess I’m asking can you turn the pressure right down to a gentle hose so I don’t blast my dog’s feet off?
The standard Worx has a High/Low button and also variable spray angle settings. Also if you use it with the short wand it will only wash at the low setting (unless of course you do the magnet hack
By caravan pump spray, do you mean the cheap Ebay/Amazon ones? Similar to what Kayak posted above?
The Worx is much more powerful and cleans off claggy mud stuck in tyre treads much quicker than my Ebay special. The Ebay special I had to hold right up to the tyre to shift the mud with the Worx hydroshot it cleans out the tread from my normal standing position that I use to rinse the whole bike, don't need to stick the lance right up against the tyre.
As above. It's possible to get the pressure down for dog washing, but she really doesn't like the noise.
I had one of the ebay ones as above. It worked really well for two washes then never worked again. Make your own mind up about what that means.
We lost our dog last year sadly, but when we get another one soon I plan to use the worx to wash them down. Our last dog would take an ice cold hose down in the garden but I had to put him in the car muddy/dirty, worx should fix that
I use the short lance with mine and can get high and low settings. Haven't used the long lance actually
I use the short lance with mine and can get high and low settings. Haven’t used the long lance actually
Pressure is over twice as much with the long lance
I don't think anything but a full power jetwash will get that off - Worx will remove a lot but you probably still need a brush.
High power short lance seems to work well enough (don't know if that was a US restriction?) and has enough power. I've jet washed my own legs a bit on high and it stings but doesn't remove the skin... on low it's fine (and the wider the nozzle setting the less intense - theres a 'shower setting' on the nozzle I've washed under).
Gave my stepfather a Worx for Christmas. It has not dissapointed. I'll be getting one, and not just for bike duties. Having a moderate jetwash anywhere is a game changer.
Worth the money is a reasonable conclusion.
I have a worx, bought because I live in a 3rd floor flat.
So i use 10L containers and the worx to wash my car.
Works really well.
I’ve used it on the bikes too, but primary use is the car.
I did buy the bigger battery though.
Similar to the above, I bought a used Worx Hydroshot from the Amazon Warehouse black Friday sale. It was in "used" condition but was complete with all accessories. I had an Amazon voucher so paid under £40 of my own money.
If I had an outside tap or somewhere to attach a hose I probably wouldn't have got it, but now I do have it I'm happy with it. Previously I used a 5 litre garden pump spray, but this works much better as the power is consistent and the water jet is wider.
You could use it for washing a dog, as there's a setting low enough to water plants.
Got my Worx in the black friday sale, already had a drill and jawsaw so plenty of batteries and chargers now.
Pressure washer does the job well without too much pressure, so very bike friendly.
Bosch Fontus the best by far.
All integrated into one unit, a lot less hassle than the modular Worx.
Has no one had the problem of the Worx not being able to draw the water through properly, as if it needs priming?
Seems to happen a lot for the people that I know that have them.
Curious as I'm on a pump up Hozel that is brilliant and have an unused Worx that I'm loathe to use as I'll flog it on if the issues the lads are having are unsolved.
Mate has a Mobi thing that has a battery and has been flawless so far this winter.
Can take about 30 secs to draw water through.
I also added a weigh to the filter end to help it sink to the bottom of the container as the hose has a tendency to curl back up (if stored coiled) which meant the pickup end /filter could end up sitting at the top of the container.
Can anyone recommend a source of bulk/cheap was additive (like mucoff or some kind of spray foam) to use with the mixer bottle?
Great for blasting mud off, doesn't get them clean-clean with just water though.
Took the filter off the pipe of Hydroshot, pushed up the float and put a foot long plastic pipe over and put the clamp back on to stop the plastic pipe falling off. That solved the problem of it curling up in a 10l container. Only use tap water so shouldn’t be a problem with grit, dirt etc.
Routine now is to wash bikes immediately at end of the ride rather than putting them on the bike rack and letting the mud dry on - it will get even the worst mud/clay off tyres etc if it’s still wet. Don’t tend to use a bike cleaner just dry the bike down with an old towel and that seems to solve the residual mud smears.
Second.. Third.. Whatever.. The WORX!
I've a 25l container in the boot.
Going to make a 'rigid pipe thing with a hozelock attachment' on it, and put another hozelock on the worx pipe, so that I just clip it on, and it always sucks from the bottom
Prob put a bit of mesh on the bottom of the pipe..
DrP
Another Hydroshot user, only used it 3-4 times and it's great. Mine seems to take 30-40 secs to get going and the filter floating to the top is a pain. Might try weighting the bottom of the house, see if that solves it.
Why aren't there more people using the Bosch Fontus ?
They are absolute quality. Fully integrated, good range of pressure settings, self contained rechargable battery, durable and solid.
It also has a pair of decent sized wheels, makes it easy to move around.
At £200, although the the Bosch Fontus does look to be the best option (apart from the size) they're probably priced a bit high for us who just want it to wash to bike after a ride. The Hydroshot can be had for well under £100, and the mobi 12v wsher is £50 regularly. Then there's the hand pump which is £10-15 and still does the job, with a bit more effort.
Silly, I know, considering we'll spend several thousand pounds on bikes and gasp at spending £100 more on something to maintain it 😀
I'll hopefully get out for a local ride on Thursday and will test out my dad's hydroshot - I normally use a decent pressure tap with a hose and find that plenty to wash even fuly dried on dirt.
Just to spice up the tread, I got one of these from the US site via a post forwarding service.
www.worx.com/40v-2x20-hydroshot-portable-power-cleaner-wg644.html
Was reduced to $170 at the time in their Jan sale. 40v version that does 450 psi (as opposed to the 20V version available in the UK\Ireland which does 320psi).
Arrived a week ago, it definitely gets sticky clay off the tyres 🙂
Does that Bosch have to be used from its tank, or can it be used with a hose/suction? Website not clear; I know the wee Kärcher can be had with a suction hose.
The Bosch has to be used from its own tank. Everything is fully integrated into one unit.
I believe the Worx is modular in comparison.
I have the little Karcher, got it then the Workz came out. Typical.
It works quite well, bought the extra hose for it to use in a water Jerry can.
Not used the Workz yet so have no opinion on it.
The little Kärcher is very compact, isn’t it?
How is it in use?
I had the small Karcher for a month: it's just enough water and force to clean a bike. I had to send mine back though as it leaked intermittenty - at the connection between the water bowser and the motor. Made a mess in my car boot. It may just have been my example but I couldnt trust it after the second leak.
@ratherbeintobago it works fine, the 4l tank is fine for when the bike is still freshly muddy. As soon as it dries you'll need more water. Which is where the additional pipe comes it, also got the car charger so I'm never without juice.
@greenskin thanks!
A couple of further questions: where does the pipe attach, and can you get more than one tank out of a battery?
I've got a Worx and its brilliant. The only thing I'd say is my pump died after 19 months of average to low use and it took them just under a month to replace it, but they did send me a brand new one.
@ratherbeintobago You remove the tank and plug the hose into the valve that draws water from the tank. The pipe has a filter on it so you can dump in pretty much any water source as well. Accessory Kit
The battery seems to last for ages, I've had it running for quite a while washing the bike when I was lazy and let the mud harden!
Very tempted with the worx, but gone for 25l water container and an ebay special for £25 total.
Only need it to get the worse off before bike goes in car in winter (bike rack usually on April to October).
Don't need the power as have two proper jet washes at home, and dont pressure wash the bike anyway. Hose pressure is enough, then bucket and sponge.
Does the Bosch Fontus use the same batteries as the blue 18v power tools?
OK, so having had a couple of hours in the SE mud today, I had a chance to test out my borrowed hydroshot. I honestly wasn't expecting that much as it has much less water flow than the tap and hose I normally use.
Colour me impressed.
Forgot to take a before pic, but we all know what it would look like: a bottom bracket somewhere beneath the layers of mud, generally covered in a good 1-3cm layer of finest Kent mud.
Anyway, I filled up a 30l bucket from a tap to under half full, and gave it a proper thorough wash, I used about 15l total.
I'd say its better than my hose, got the ingrained mud on the saddle off, and stuff like the brake calipers are nice and clean.
[url= https://live.staticflickr.com/65535/49394318937_03ea7e1549_b.jp g" target="_blank">https://live.staticflickr.com/65535/49394318937_03ea7e1549_b.jp g"/> [/img][/url]
I'll be looking for a hydroshot on sale in the next month or 2, unless the bosch goes on a decent sale. I'll get a 25l plastic water container for my boot and strap it in permanently then with the hose I can leave it in there and use the hydroshot from the boot.
Next random question - is there a foam attachment for either the Bosch or the Karcher?
The bosch doesn't have a proper lance adapter does it, nor does the karcher. So you're stuck with the rubbish soap bottle they come with, no option for a proper snow foam lance (not that the hydroshot would be any good due to lack of waterflow/pressure).
Has anyone bought the brushless hydroshot yet? Any reviews? Tempted by it, I've got £45 worth of nectar vouchers and argos have it for £200...
It's a bit more beastly than the standard one:
[img]
[/img]
vs
I'm tempted to see if I can modify the k series foam nozzle to fit my OC3. I shall let you know.
I'm still loving my £50 mobi v15, used it loads and it's perfect so far 👍👍😁
Thought I'd revive this as I've now used my worx hydroshot brushless (wg630) a couple of times.
Bloody brilliant.
I went for a night ride on my gravel bike on Sunday, and it got absolutely caked in mud. Forgot about it until today (been working lates so washing the bike at 9pm wasn't appealing), so it was covered in week old, dried on mud - started on the chain with some neat fenwicks in the x-tools pro chain cleaner - the chain was so bad I had trouble turning the cranks. Then I doused the entire bike in a spray of 1-10 mix fenwicks, and left it 5 minutes while I got the hydroshot out.
10 minutes on the 25 degree and 15 degree jets, with no brushing required, and it's spotless again. I'll get some protect and shine spray when they're in aldi next and with the chain dried and lubed, a quick wipe down to dry the bike, I'm done.
I've now got a 25l water container strapped into the boot of my car so I'll fill that up before going out on the mtb, that's probably enough water and battery to do 3 bikes.
Anyone had to replace the hose on the Worx Hydroshot?
Despite the filter, mine seems to have gotten blocked up with black gunk.
I can only assume I must have left water in it and it grew a fat organism.
I ordered some with the right OD diameter, but the id is too big.
Has to be something cheaper than the genuine hose at about £30. I don't need all the filter and shizzle obvs.
Can you not soak it and try and wash out the blockage? I made the mistake of leaving water in my portable washer over the winter and the water almost turned to jelly! Hot soapy water and rinsing under the tap sorted it all out
