Ok just nitromorsed a 10+ year old Marin, now I am going to treat it to a few under coats and a about 6 top coats, only decision is what spray paint would be suitable, ideally from B&Q?
It's for my wife so ideally pink or green or something a bit different. So any ideas on what [paint (type and brand)? Only one I have found was this
Why B and Q? If I was you, I would call in to my local automotive paint supplier and choose any colour from the rainbow you like. They will mix it and put it into an aerosol for around £12 per 500ml can.
only as I have £40 in B&Q vouchers to get rid of
Fair enough its B and Q then. The only problem with off the shelf aerosols is the opacity is usualy a little weak so you need to keep builing up the coats so it will cover.
b&q do plasicoat (sp?) i would also laquer the bike once it is done.
im geting mrs. 1111's bike powder coated for £40 but as you have said you have the vouchers!!
call it a project I want to fully renovate it from top to bottom on my tod, its fully stripped, all the paint has gone....
