what length seatpost should I get? 300mm or 400mm?
for a medium Cotic Soul, I'm 5'9 with a 31" inside leg
ta
I predict 300mm will be too small. 400mm a bit too long but better than too short. I'm 5.10 and mine needs most of a 400mm post.
thanks
I thought I'd need 400ish mm - you often pay the same as 300mm, just the one I want isn't in stock in 400mm
rule of thumb is to make sure there's at least 4 fingers width of seatpost within the main triangle (i.e. below the top tube/seat tube junction).
You need 100mm of seatpost insertion in a Soul (i.e. 10mm below the bottom of the top tube). Most people need a 400mm post, but you'd probably be OK with a 350mm with that frame size/leg length combo.
magic, thanks Cy
If you need a temp post till you can get a 400mm then CRC have [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=48196 ]THESE[/url] for £7.99. Heavy as ****, but for £8 !!!
how heavy can it be?
twice as heavy as a light one?
meh
You're most welcome 🙄
