What is this bit fo...
[Closed] What is this bit for?
Shimano BR RS785 brake caliper
Does anyone know what the little black tubes are for that come with Shimano BR RS785 brake calipers?
Posted : 01/10/2020 10:29 am
I believe that's the collar that you put on the tube when bleeding the brakes.
Push it along the tube and tight up to the nipple, and it 'locks on' so to speak
Posted : 01/10/2020 10:40 am
My guess is that they go between the bolt and caliper (i.e. slip inside the bolt holes in the caliper). I've never noticed them on Shimano MTB calipers so I checked an online manual, but couldn't see them on a brief skim, so that's just a guess.
Edit: LittleNose makes more sense to me.
Posted : 01/10/2020 10:42 am
@LittleNose that makes sense, thanks
Posted : 01/10/2020 11:40 am
Little black bits go over the ends of the spring to keep it springy while in the packaging .
Posted : 01/10/2020 11:45 am
+1 as Cheesybeenz says.
However, what is the little split ring thing on the LH of the picture for, what does that do ?
Posted : 01/10/2020 11:48 am
There should be two of them. It's (supposed to be) a locking ring for the bolts. It'll stop the bolts unwinding if they aren't tightened. Completely useless.
Posted : 01/10/2020 11:53 am
