What is the point o...
[Closed] What is the point of dual chainrings ?
More gears = more gearing options!
Posted : 26/01/2012 11:21 am
What's the point of a triple if you never use the big ring???
Double and lightweight bash suits me.
Posted : 26/01/2012 11:39 am
I tried running triple and a close ratio road cassette, rubbish, pretty much everytime I changed gear offroad I'd move 2 at a time anyway and I had to switch chainrings a lot more often. I run 22/32 11-32 mostly now, slightly undergeared for downhill fireroads but as I only ride those once in a while it's fine.
22/36 11-32 has more top end but I like a 1:1 available in middle ring, lots of climbs seem to be just a bit too steep/long for 36/32 so too much use of the granny, wouldn't mind 24/36 11-36 10spd but CBA with the cost and effort at the moment (and I like my RR dérailleurs too)
I've got an ultegra on my race wheels was 12-28 I think but I put an 11t in to make it 11-28T.
Works very well with a triple I find.
I reckon 22f-28r gives me a low enough for going up hills and a 42f 11r gives me enough for road riding even.
but a 11T-30T 8 speed would be even better and probably weigh the same as a 9 speed 11-28T.
Posted : 26/01/2012 11:49 am
Of course you could go down the Sheldon Brown route of 63 gears
http://sheldonbrown.com/otb.html
Posted : 26/01/2012 11:50 am
Do it on a Rohloff, with a 10 speed cassette and a triple. Maybe a Hammerschmidt too, for good measure. And Di2. That would clearly be the best bike ever.
Do you not just find yourself shifting chainrings the whole time? That was what I found frustrating. With a wide range cassette I could just drop a gear at the back. With a close ratio block I'd have to drop 2, as one would be too close, then change down (or up) on the front sooner.
Good at Thetford and Sherwood, but no use anywhere else I found!
Posted : 26/01/2012 12:04 pm
What ever happened to all the 54t big rings we used to have in the early 90's, the ones that were designed to race the kamikaze that we lugged all over Leicestershire looking for a hill that took more than 4 pedal strokes to get to the bottom of. All this 36t is enough is a clear inicater of mincers.
Oh, and the same time, sun tour micro drive never took off because it'd wear out too fast...
Posted : 26/01/2012 12:07 pm
You pedal over 30 mph offroad?
Posted : 26/01/2012 12:08 pm
Clearly tongue in cheek...
But yes, sometimes. If the trails open enough, and the hills steep enough. But mainly on the road on the way too and from the trails. Sadly I only live close too, not actually on the local trails so have to get to and from them.
Posted : 26/01/2012 12:16 pm
Less gears, pedel faster, pedel harder, pedel longer = fitter, better rider.
Why spead so much time messing around with your gears, spend the time riding your bike!
Posted : 26/01/2012 12:20 pm
Transapp - I realised on second reading - DoH!
Posted : 26/01/2012 12:22 pm
Just done the sums. Stock SRAM 2x10 setup costs me more than XT 3x9 or 3x10, and loses me a bunch off the top end and my lowest grind up the mountain gear. Why pay more for less? Think I'll stick with stock Shimano 3x9/10 tyvm.
Now going 1x10 kind of makes sense and eliminates the overlap. Does anyone know who can make me a 12-56 or a 12-60 10sp cassette? and a rear mech to match? 😉
Posted : 26/01/2012 12:40 pm
22/36 chainringgs mean you only loose the top two gears - those ones that are never used offroad.
Posted : 26/01/2012 12:42 pm
But some people ride on the road as well?
Posted : 26/01/2012 12:44 pm
You still need to pedal above 30 mph on a mountain bike even on road?
Posted : 26/01/2012 12:45 pm
I run 28/40 up front against an 11-28 (9 speed) cassette in the back. Less duplicated ratios and lighter as well.
Posted : 26/01/2012 12:47 pm
No, but at 100rpm in 36/11 you're doing 25, seeing as road is likely to be something either done for fitness or to be endured as a way of getting to the trails it'd be nice if you didn't run out!
Don't get me wrong - I've got a 36/11 top gear, and often ride 16 miles each way on the road to get to the off-road bits, but if I was gonna try a different chainring it would definitely be a 38 not a 34.
Yeah, but more shifting on the front and irritating multiple shifts on the back - keep up, we just did that 🙂
Posted : 26/01/2012 12:48 pm
Occasionally I would like a higher gear - but its so much better not to have to do multiple front shifts and to have the clearance and lack of leg biting big ring.
Posted : 26/01/2012 12:51 pm
but its so much better not to have to do [s]multiple[/s] front shifts
FTFY 🙂
Posted : 26/01/2012 12:52 pm
[url= http://singletrackworld.com/forum/topic/ok-trying-to-understand-1-x-10 ]1x10 already covered this week[/url]
Posted : 26/01/2012 12:58 pm
I can nearly get SRAM 2x10 26/39 to a Shimano 11-36 cassette to work. Better than SRAM 12-36 cassette, anyway.
Means losing top gear and bottom gear, and bailing to granny earlier. Or use 180cm cranks for a tiny bit more leverage.
Actually, with a bit of jiggery pokery, I could get that daft 1x10 cassette down to an 11-52, to give me all the ratios I want (need != want).
Posted : 26/01/2012 1:21 pm
"I suppose some people live in houses that are already off-road so they don't have to cycle along roads to get there, but I unfortunately do live on a road, so I have to cycle along it to get to the off-road."
If you cycle on decent mtb tyres on road @ over 25mph then this is a valid point, personally I can't unless I am going downhill. I do prefer to spin rather than mash a big gear though...
Posted : 26/01/2012 1:25 pm
Jesus, [i]tiny [/i]bit more leverage!? Ground clearance would be an issue.
What do you mean nearly? There's no reason that a SRAM 26/39 chainset won't work with an 11-36 Shimano block? 😕
I tend to always average 90-95rpm so not a masher, if not a crazy spinner, and do find myself right at the top end on the road. Only takes a very slight downhill to make a big difference.
Posted : 26/01/2012 1:26 pm
Extra ratio at the top end.
With shimano cassette, it's like losing only 44-11 (which I could live with).
The "nearly" bit is referring to the fact that after quite a bit of number crunching, there is a 2x10 setup using stock available components (ie no swapping of rings) which nearly covers what I've already got with 3x9. Some people only use middle ratios, get an uplift and never do fast trails/roads. Others use the full extremes.
Posted : 26/01/2012 1:33 pm
For me its nothing to do with weight saving and everything to do with correct gearing.
26-38 with a 11-36 seems to me to be the best comb for me.
I almost never use the 42 tooth big ring and a 26-36 combo can climb just about anything.
I find the 22 tooth ring just lifts the fort wheel and i loose control, its a hard life having all this awsome leg power 😀
Posted : 26/01/2012 1:37 pm
+1, think that was my first post on the matter!
Posted : 26/01/2012 1:53 pm
Funnily a 44/42T outer ring is cheaper than a lot of bash rings and will save your middle ring from damage just as well... (okay, maybe not the back of your shins)
If you're clouting your outer ring off rocks, your just riding it wrong.
That said I have the parts to go 2x9 next (24,36, bash) I feel like 22/32 is too small for me.
10 speed? - well maybe in 4-5years when I run out of 9 speed bits or they become impossible to get.
Posted : 26/01/2012 10:53 pm
kaesae - Member
It's almost entirely duplication. Triple rings are like carrying around 2 multitools, 2 pumps, 2 sandwiches, 2 raincoats...
oliverd1981 - Member
Genuine LOL.
Posted : 26/01/2012 10:58 pm
Don't need a special chainset - just use the inner and middle ring positions on a triple. I've done 30/42 and 28/40 like that.
Works better on a 68mm BB shell so you can move the chainline over a bit to centre the 2 rings but yes that will work if you can get the rings and are okay with a 28T granny (I'm not, especially where I live. If I move east I will fine though!)
Posted : 26/01/2012 11:44 pm
Sadly, many people have no patience and can't be bothered to learn anything anymore - seems like 2*10 is perfect for the 'can't be arsed to read the manual' crowd.
That is why I took the time to swap out my crank, front DR, rear DR, shorten the chain and mess about with BB spacers and chain line. No patience me
Posted : 26/01/2012 11:54 pm
Page 3 / 3
