What is / How to us...
[Closed] What is / How to use this 10mm Thru Axle ? is it a DT RWS axle.
Hi,
I've got some vision disc 30 wheels which can only be converted to 10mm thru axle.
On another bike I have the aluminium hadley 10mm thru axle which is great. I know the superstar ones are available but they are very heavy.
Anyway searching through my parts box I found this.10mm bolt thru
I think I got it on a 2nd wheels years ago.
The problem is I dont have the tool to use it.
Is it a very old DT SWISS RWS Axle ?
This image looks similar to it ? all the new ones seem use a allen key fitting.
DT swiss axle
Posted : 06/09/2019 1:08 pm
Yep, it's what's left of a DT Swiss RWS through bolt when you chew up the original, soft, Nylon lever. The new ones use an alloy lever that works far better. I don't think you can buy the aluminium lever separately though.
Edit: I might have an aluminium lever assembly lying about - long story - I'll have a look later.
Posted : 06/09/2019 1:18 pm
Cheers Badly Wired Dog,
I wonder if I could dipped it in some solvent ... the end might unscrew and I could just put a normal bolt on it.
Posted : 06/09/2019 1:30 pm
