What is a good grea...
[Closed] What is a good grease or oil for my chain?
Now that I'm replacing most of my drive train I've decided that I should probably take better care of my chain. I've used organic oil and dry wax chain lube but the chain seems to go dry very quickly.
What should I be using to keep my chain nice and lubed and what good for cleaning the chain?
Thanks.
Posted : 19/04/2011 8:02 pm
 Keef
snake oil.....
Posted : 19/04/2011 8:58 pm
We use wax lube for the hire fleet. Less rubbish picked up and sticking to the chain. A quick wipe down afterwards with a rag and re-apply for rattle-free chains. Little or no muck on the freewheel and between the sprockets as well. I had to degrease with an orange based product to remove the previous lube before using the wax stuff though. I'm running a long term test on this as the local trails and roads can get very sandy/gritty.
Posted : 19/04/2011 9:50 pm
I've given up on dry/wax lubes, as they need constant re-application (after every single ride), and cost far too much.
TBh, I've found 3-in-1 type oils to last the longest, and give best performance in very wet conditions, but they do get very grimy, and cleaning is a proper PITA. Cheap as anything though. 'Wet' type cycle chain lubes are ok. The 'dry' type ones stay much cleaner but just don't really do that good a job of actually providing lubrication to a constantly moving part. I spose the less grimy a chain is, the better it will last, but it's no good if it's all fallen off by the end of a ride and you've got a squeaky chain.
Posted : 19/04/2011 9:57 pm
Weldtite TF2 grease on my chain...
Posted : 19/04/2011 10:03 pm
I'm liking juice lubes dry the now.
Posted : 19/04/2011 10:05 pm
Like what Elfinsays,
I use finish line wet all year round, but I cheat by having three chains in constant circulation - clean on the bike, being degreased and clean waiting for use. Spreads wear that way too.
I got three years out of the last three chains, single cassette and chainring - I can live with that.
Posted : 19/04/2011 10:10 pm
I like the Squirt lube. Follow the instrcutions and it works well.
Posted : 19/04/2011 10:13 pm
Car gearbox oil as recommend by (among many others) Regina, Honda, & me. The fact that it costs about £8 per litre as opposed to about £60 a litre for say Finish Line Cross Country is an added bonus too.
Rumours abound that the best chain lube tested by one mag/site is actually re-bottled gear oil...amazing how quick people catch on (I was taught to use gear oil over 40 years ago).
Posted : 19/04/2011 11:13 pm
3 in 1 oil + three chains in constant circulation
sorted !!
Posted : 20/04/2011 12:11 am
putoline motorcyle chain wax, cheap. longlasting, works well, filthy faff to apply. Significantly increased chain life since I started using it
Posted : 20/04/2011 12:28 am
